Seals for AC system...
Old May 3, 2003 | 05:39 PM
craigffb's Avatar
Are there seals on the AC lines? My AC stopped working so I'm gonna replace the pump and Dryer, but I figured I should do all the seals as well if it even has any.
Old May 5, 2003 | 11:39 AM
craigffb's Avatar
Wow,
No body knows if there are seals or gaskets on the AC lines?
Old May 5, 2003 | 11:45 AM
Don 97 SS's Avatar
Well, I removed a line when I did the cam install recently and I don't recall any gasket or seal per say. The again I'm no A/C expert.
Old May 5, 2003 | 02:16 PM
craigffb's Avatar
Thanks Don. I wonder if Rob has it in his book or what ever he uses to get part numbers?
Old May 5, 2003 | 02:39 PM
Is that a hint?
Take a look at this diagram from my Tech Page and tell me what numbered items you are goint to be messin' with. 3, 13, 24 and 30 are all o-rings.
Actually, all but 24 are p/n 52454645 .
24 is 52458698
Old May 5, 2003 | 02:54 PM
craigffb's Avatar
Originally posted by shoebox
Is that a hint?
24 is 52458698
I thought that might get ya. I'm gonna put in a new pump and dryer. But I think my lines mybe leaking at 22. So the part numbers you gave me should work. Can you tell what 32 is, where the lines go into the backside of the pump? Might need a part number on that as well depending on what it is.
Thanks Rob.
Old May 5, 2003 | 03:38 PM
Thanks Rob.
Oops, missed 32. Those are p/n 2724577.
Old May 5, 2003 | 03:55 PM
craigffb's Avatar
Thanks. I got that one from the local dealer. These things are expensive!!
52454645 - $7.48 ea.
52458698 - $1.31 ea.
2724577 - $7.68 for the kit (has both of then)
I'm waiting for a call back from Jason. Hopefully they be a little more reasonable from him.
colts0455
Sep 27, 2015 01:07 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
95mysticta
Aug 20, 2015 07:43 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
Bails098
Aug 17, 2015 05:15 PM
