Can The Opti Be Installed Wrong?
Old Aug 1, 2007 | 11:41 AM
RKHiPerformance's Avatar
I just installed a new GM Opti in our 1996 Z28. I have not done any further re-assembly.
If the Opti unit seats flush against the timing cover before the bolts are threaded, does that mean it is indexed correctly?
Thank you for the confirmation,
Rick
Old Aug 1, 2007 | 11:48 AM
Z28SORR's Avatar
Anything can be installed wrong. And I don't believe sitting flush is a guaranty.
Is the rotor pointed at the exact same clock angle as the old one. You did mark it??
Stl94LT1's Avatar
The opti can be forced on wrong. But, if it easily slides against the timing cover, it should be right.
Old Aug 1, 2007 | 11:52 AM
Stl94LT1's Avatar
Oh, briefly start the engine before reinstalling the water pump and other accessaries. This may help avoid another teardown.
Old Aug 1, 2007 | 11:53 AM
wrd1972's Avatar
It can easily be installed wrong, but here is the trick to doing it painlessly.
You can run the motor without the water pump attached to test the opti for correct install. Let it run for about 10 seconds and you will know if you did it right.
warmeck
Mar 22, 2015 10:28 AM
grabbem88
Mar 18, 2015 01:25 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
GigaMp3z
Feb 20, 2003 02:57 PM
