Can The Opti Be Installed Wrong?
I just installed a new GM Opti in our 1996 Z28. I have not done any further re-assembly.
If the Opti unit seats flush against the timing cover before the bolts are threaded, does that mean it is indexed correctly?
Thank you for the confirmation,
Rick
Rick
It can easily be installed wrong, but here is the trick to doing it painlessly.
You can run the motor without the water pump attached to test the opti for correct install. Let it run for about 10 seconds and you will know if you did it right.
grabbem88
Mar 18, 2015 01:25 PM
