can i run a smaller oil filter?
Old Feb 28, 2006 | 06:04 PM
T/A Racer's Avatar
due to buying used headers which i didnt know the flanges were way warped on i had to surface the sh#t out of them to get em flat again. now the drivers side hits on my oil filter hard. what should i do? can i run a smaller filter?
Old Feb 28, 2006 | 06:19 PM
LiENUS's Avatar
Re: can i run a smaller oil filter?
The ideal solution in this instance is to get a second header flange and sandwich it between the head and the header, I believe ACDelco PF25 is the smallest oil filter you can run so if PF25 wont work try and see about getting a second header flange (may need to get it milled enough to fit your headerbolts)
Old Feb 28, 2006 | 07:44 PM
OBE1 95Z28's Avatar
I would bring the header to a good exhaust shop and see what they charge to replace the header flange. I wouldn't want to compromise the oil system.
Old Feb 28, 2006 | 09:04 PM
T/A Racer's Avatar
can anyone tell me aprox. how much clearance there is between your oil filter and pacesetter LT's. i know i surfaced off quite a bit but i dont think it should be this much. im thinking about putting about my oil cooler back on with a block off plate in order to get the filter down a little lower and hopefully help with clearance.
HectorM52
Jul 30, 2017 11:46 AM
parkers Z28
Mar 11, 2016 08:14 PM
PCLZ28
Dec 24, 2015 05:19 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
