Can i cut an reuse the DLETEQ plug wire?
Ok here is the deal im running a fairly new Delteq ignition system(less than 80miles).I really dont like the stock route of the plug wire.
So i made my own custom OTVC wire and its much cleaner and safer now
BUT...
The Delteq wire are way way way did i say way to long now.They are making huge loop over my intake
.I dont wanna buy a new set of cut to length wire since those are NEW!
My question:
-Can i cut the plug wire to the good length and reuse the plug boot and metal plug connector?
-Do i need a special crimping tool or a standard pair of plyer should do the trick?
Thank you
BUT...
.I dont wanna buy a new set of cut to length wire since those are NEW!My question:
Thank you
Yes, you can cut and lengthen them
These will do the trick:
http://store.summitracing.com/partde...5&autoview=sku
And if you have a few extra buck these work great http://store.summitracing.com/partde...5&autoview=sku much nicer crimp.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
grabbem88
Mar 18, 2015 01:25 PM
