clearity about the opti
To test the low res pulse turn the key to the run position an turn the crank over by the balancer hub bolt. You can do this with a breaker bar and socket.
As you manually turn the crank you should hear the injectors momentarily kick on in a similar fashion that they do when you turn the key from the off position to the run position.
Also if the low res fails you should get a code, I think 16 but I might be wrong.
Formula Steve
Sep 19, 2023 08:31 AM
