Can a arching plug wire cause the plug to foul?
Old Dec 22, 2005 | 09:05 AM
gamecockfan04's Avatar
Probably a stupid question, but I had a burnt wire #5 that was arching against the block. I put an old one on just till my Elite OTVC wires come in, but halfway to work the morning I can tell another wire is arching(probably the same one). So Im just wondering if driving the car like that will cause the plug to go bad.
Old Dec 22, 2005 | 09:34 AM
JohnD's Avatar
Re: Can a arching plug wire cause the plug to foul?
I don't know about causing the plug to foul but when my car had a plug wire not seated on the plug just right it had a bad miss and set a "check engine" light.
Old Dec 22, 2005 | 11:32 AM
1racerdude's Avatar
Won't hurt the plug,but will hurt the opti if the spark has nowhere to go. It will back up in the opti and cause carbon tracking in the cap.
Old Dec 22, 2005 | 11:46 AM
96flame's Avatar
If its arcing out to the block and the plug isn't firing then yes the plug will get fouled by the fuel not being burnt everytime that cylinder is supposed to fire. Most plugs will be okay after they dry out but some are junk.
Old Dec 24, 2005 | 05:14 AM
pillagenburn's Avatar
unburnt fuel + possible fuel detonation in the pipes + o2 sensors = fawked o2 sensors
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
eanhl2004
Apr 4, 2015 12:01 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
gh0st
Sep 1, 2002 10:24 AM
