Camaro engine swap
Old Jan 17, 2007 | 08:39 PM
arnold's Avatar
Camaro engine swap
I have a 1991 Camaro RS with a 305 engine and want to swap it with LT1 or 350 engine. I live in California so it has to pass smog. Can this be done and with what adjustments?
Old Jan 17, 2007 | 08:41 PM
reamo04's Avatar
I'm sure it can be done. LT1s pass smog in stock form
so, u could just swap everything over out of a LT1 car, and it'd probably pass
Old Jan 17, 2007 | 09:10 PM
arnold's Avatar
I have a 305 in a RS now, so what would I have to swap besides the engine to get it to pass smog? A shop is doing the work, so they won't warranty the labor on any parts that I supply.
Old Jan 17, 2007 | 09:34 PM
reamo04's Avatar
you'd have to swap the headers, smog and air pump, that should be about it. If u want more power, u can get some MAC midlength headers that are smog compliant, and a catted-ypipe with a cat-back.
Old Jan 17, 2007 | 09:55 PM
arnold's Avatar
Can a 350 engine be modified to be as high in hp and torque as a LT1?
It would be much easier to use the 350 to pass smog.
Old Jan 17, 2007 | 09:56 PM
reamo04's Avatar
yes. My friend has a truck w/ an old carbed 350 that puts out a lot more power than my LT1. Older 350s are cheaper and easier to work on too
Old Jan 17, 2007 | 10:10 PM
arnold's Avatar
So what would I have to modify on the 350 to get it up to the LT1's performance and still have it pass smog?
Old Jan 17, 2007 | 10:14 PM
reamo04's Avatar
IDK about passing smog in a carburated setup.
u could probably do it with the L98 though
dont u guys have to pass like the BAR inspection or something in california?
Old Jan 17, 2007 | 10:25 PM
arnold's Avatar
The 350 would be a 1991 so it would have fuel injection, not a carb. Are a new fuel injection, ecm and headers be something I could add after the install and still have it pass smog in CA.
Old Jan 18, 2007 | 03:25 AM
2000GTP's Avatar
If the parts you buy have CARB stickers, then you should be good to go in California.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
deadmanrunning
Jan 3, 2015 01:12 PM
nballisru
Dec 14, 2014 05:01 PM
cmdeshon
Dec 12, 2014 10:51 PM
Jul 4, 2005 05:00 PM
