Cam selection and install help
Old Feb 25, 2006 | 12:17 PM
  #16
rskrause's Avatar
Moderator
Re: Cam selection and install help
Originally Posted by j0n
hows the following sound for a start to a parts list:
-ARP-134-7103
-CRN-11755-1
-any brand hardened 5/16" pushrods
-lt4 composite valve covers(are these the only covers that will fit with a stock-location alternator and allow clearance for the crane rockers?)
I'll pick up the gaskets ill need from the local napa
where should i buy the cam/springs/locks from? which should i go with?
also what kind of timing chain/sprocket set would be fine for my application? just a stock replacement?
Get the "narrow body" rockers designed for motors with center-bolt valve covers and they will fit under stock valve covers (with some trimming).
Rich
Old Feb 25, 2006 | 12:27 PM
  #17
SStrokerAce's Avatar
CCA-1305-16 Rocker Arms
And a 1 piece 4130 pushrod, NOT just a hardened one.
Bret
DirtyDaveW
Dec 1, 2016 05:37 PM
mikey4play
Mar 15, 2015 11:45 AM
Jan 23, 2015 01:13 PM
Dec 17, 2014 11:00 AM
Noenav
Dec 6, 2014 07:35 PM
