cam lift question
He also has a "custom tuned ECM"; if the idle speed was lowered the car will have more 'lope'
If you are really interested you should be able to measure the lift with a dial indicator. It may not be super accurate unless you can account for any collapse of the hydraulic lifter. If you can measure anything more than .500 lift at the valve you have an aftermarket cam.
thank you , i wanted to make sure , that i could do that and it would be semi accurate
