cam lift question
Old Sep 25, 2009 | 07:12 AM
  #16
ChevalierSS's Avatar
Originally Posted by '94 Bad A Z28
Wait a minuet, it says in your signature that you have "comp roller rockers" so you know the answer to your own question. I am sure you didn't buy 1.5rr's (stock ratio) if you actually took the time to get them and install them on your stock cam.
He also has a "custom tuned ECM"; if the idle speed was lowered the car will have more 'lope'
Old Sep 25, 2009 | 09:23 AM
  #17
87bandit's Avatar
wow lol
Old Sep 25, 2009 | 09:37 AM
  #18
The Untouchable's Avatar
Originally Posted by 87bandit
wow lol
lol
no my idle is set at a factory specs
Old Sep 25, 2009 | 12:00 PM
  #19
Originally Posted by 94Sleeper
If you are really interested you should be able to measure the lift with a dial indicator. It may not be super accurate unless you can account for any collapse of the hydraulic lifter. If you can measure anything more than .500 lift at the valve you have an aftermarket cam.
thank you , i wanted to make sure , that i could do that and it would be semi accurate
LeftoverChinese
Jan 14, 2024 03:03 PM
rideordie
Nov 5, 2019 04:52 PM
kandied91z
Jan 23, 2015 11:14 AM
1775.Z28
Jan 11, 2015 10:51 AM
