Cam install question - Do I need oil?
Old Aug 3, 2008 | 04:17 PM
Mtxz453's Avatar
The cam is in and timing cover is all hooked back up. Here is how my engine stands right now. I'm putting in the new springs but have cranked the engine and spun the cam a couple of times between putting the timing chain back on, finding TDC etc. I used 20w-50 oil instead of assembly lube when I put the cam in. As it sits now it does not have any oil in it. The lifters and pushrods are out as you can see and I need to crank the engine to put the piston all the way up in each cylinder so the valves do not drop in while I'm doing the springs. I'm scared to keep turning the engine without any oil in it, so can fill the oil in through the valvetrain and then prime the pump and engine with my tool to make sure the cam and crank bearings are well oiled? Here is where I am right now:
Old Aug 3, 2008 | 06:54 PM
Yes, add oil and prime it. Much better than not doing it.
Old Aug 3, 2008 | 07:17 PM
cnorton's Avatar
Be sure that the damper hub is installed before you pour a quantity of oil into the pan.
Old Aug 3, 2008 | 07:21 PM
rskrause's Avatar
Moderator
Take the cam back out and put lube on it.
Rich
Old Aug 3, 2008 | 09:40 PM
ricehammer's Avatar
^ +1
Old Aug 3, 2008 | 09:45 PM
FlamingChicken's Avatar
i forgot about the hub when i was filling mine. just started hearing a drip and oil was pouring out the front. you could just pour the oil in the lifter valley but ive always used assy lube on the cam and other internal parts
Old Aug 3, 2008 | 11:30 PM
JoeliusZ28's Avatar
I used Lucas Oil Stabilizer as cam lube for when i was hand cranking it over all the time. Then I primed my oil pump before starting it and I didnt have any abnormal valvetrain noise when i first started it.
Old Aug 4, 2008 | 12:29 AM
Mtxz453's Avatar
yea hub is on and i filled it with oil.. did the one head's springs, tomorrow I will do the others. thanks guys.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
