Cam Install
Old Dec 26, 2007 | 09:23 AM
lt1loudmouth07
Guest
Posts: n/a
Cam Install
Do i have to take my oil pan out to do a cam install ?
Old Dec 26, 2007 | 09:59 AM
wht-z's Avatar
no just drop the front of it
Old Dec 26, 2007 | 04:18 PM
Wild1's Avatar
Loosen up all of the bolts on the pan then drop the front as mentioned earlier. The reason to drop the front of the pan is to remove the timing cover.
Old Dec 26, 2007 | 04:24 PM
truedualws6's Avatar
Exactly as stated previously. I removed most of the front pan bolts and then adjusted the others accordingly to create a slight nose down angle on the pan. You will need to carefully work your way around the gasket to make sure it releases and be extra carful around the front of the pan at the timing cover. I had to run a small flat blade screwdriver along the timing cover slot to release the gasket.
Old Dec 26, 2007 | 04:37 PM
wrd1972's Avatar
Dont tear the oil pan gasket, or it will leak.
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
