cags ?
Old May 6, 2004 | 07:51 PM
polcat1p's Avatar
cags ?
Do i need to put a resistor in my cags connector if im not using it?
The connector is just ziptied .
Old May 6, 2004 | 10:51 PM
Are you using the 93 ECM with the "93 LT1"? If so, 93 didn't have "skip shift". In that case, you have nothing to plug into the M6 skip shift solenoid.
If you are somehow using a 94 PCM, all you need to do is leave the connector unplugged. OBD-I does not light up the SES light for a missing skip shift connection. It does set DTC 84 in the PCM, but that won't hurt anything. It's the OBD-II cars that must have the resistor to eliminate the SES light.
Old May 7, 2004 | 03:48 PM
polcat1p's Avatar
Cool, thanks. Im using a 94 pcm, and i did get a code 84 when i scaned it, but there was no ses light. I was just wondering if it was ok to just leave it unplugged.
HarleyZ28
Oct 5, 2015 06:23 AM
mattman
Sep 21, 2004 02:23 PM
Achilles97
Sep 13, 2002 10:49 AM
troywg
Sep 12, 2002 07:28 PM
WS6Cruisa
Jun 11, 2002 04:33 AM
