bypassed tb, BIG PROBLEM!
Old Nov 17, 2003 | 08:32 PM
  #16
st08x's Avatar
it's really not hesitating anymore , the plugs and wires are new has of july, i guess the opti dried out, i hope it keeps goin
Old Nov 17, 2003 | 11:04 PM
  #17
93Z286Speed's Avatar
My 93 Z28 TB Bypass experince
did all the bypass stuff lost a little coolant blah blah
SAME THING HAPPENED my car ran like CRRRRRAAAAAAAAP! same thing.. next day she was a champ again! little hesitation in higher RPM range though.... after a few mmonths it just annoyed the crap outta me! turned out to be the opti! i think its your opti! hope im wrong though there never fun
Old Nov 17, 2003 | 11:09 PM
  #18
st08x's Avatar
thanks a lot to everyone who replied, i think it was just my opti, hopefully it will keep working for a while.
Old Nov 18, 2003 | 12:44 AM
  #19
Chris 94Z A4's Avatar
Glad to hear that it is ok for now. Since your opti was exposed to water/coolant, the internals will degrade faster than normal due to corrosion. You should start shopping and saving for a new opti now, so that you will have it handy when the current opti gives up. A new timing chain is good insurance too.
Old Nov 18, 2003 | 08:41 PM
  #20
Bud M's Avatar
Guys! Put some towels under any hoses you remove above the opti! Opti + coolant = trouble!
Old Nov 18, 2003 | 08:49 PM
  #21
94zLT1's Avatar
ya i had some work done on my 94 Z and they dripped some coolant on my opti and it immediately shorted out and they wanted me to pay for a whole new one.
Old Nov 18, 2003 | 09:33 PM
  #22
ninetythreez's Avatar
I don't think the hair dryer will do much good on a non vented opti on a 93 if it really got soaked. If it goes away completely- great! If not, you probably dripped enuff to mess up the opti. Any liquid is the Opti's enemy.
Water=Optispark / Kryptonite=Superman.
If you end up replacing a bad optispark, I would advise the upgrade to a 95-97 vacuum vented opti is the way to go. the venting pulls moisture out of the distributor. The only bad thing about the upgrade is it requires a 95-97 cam unless there is some kind of adapter for the cam dowel that drives the opti.
Good Luck!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ced8
Jul 8, 2002 11:03 AM
