Burnt plug wire
Old Nov 26, 2005 | 05:43 PM
NAUA's Avatar
Burnt plug wire
This may sound crazy but this is the third time that I have a burnt plug wire. Same one, drivers side next to the fire wall. There is no room, its way to close to the mantifold. How the F.%$# can I stop this.
duke
Old Nov 26, 2005 | 05:48 PM
MyShibbyZ28's Avatar
Re: Burnt plug wire
Is it burning from the manifold? Still got that metal boot that goes over it? Could try header wrap...
Old Nov 26, 2005 | 07:37 PM
2fbodies2NV's Avatar
Re: Burnt plug wire
I'm guessing you're talking about #7 ? You using a 90* boot? Is it ran through the channel against the block ? I found it's easier to run the wire through if you loosen the (2?)bolts holding the channel on. I used MSD wire covering. It comes in a roll that you cut to proper length and heat shrink sleeves around the ends. I paid like $30 for the roll and had left over. When I took a spare piece of it and an old 8.8 accell wire and burnt it with a torch type lighter, it barely made the wire brown and only discolored the fabric. GOOD STUFF !
Old Nov 27, 2005 | 12:01 PM
nader454's Avatar
Re: Burnt plug wire
I got the over the valve cover kit from thunder racing. It took care of all the plug wire issues. I tried the boot covers, they worked for a while but eventually cooked through.
Old Nov 27, 2005 | 01:19 PM
pHEnomIC's Avatar
Re: Burnt plug wire
I used one of those secure ties that you pull the thing through the loop and then the only way to get it off is to cut it. Anyhow, I fastened it away from the oil fill tube and the header and it didnt burn yet.
Without the ties, I burnt 2 wires.
Old Nov 27, 2005 | 05:54 PM
Re: Burnt plug wire
How do you get the oil in that wee little tube?? Sorry, couldn't resist. He's on the driver's side where there's really nothing to zip tie(cable tie) to.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
