which bolts for my hooker shorties?
Old Sep 15, 2004 | 04:38 PM
joebeemish's Avatar
The stock exhaust manifold bolts are difficult to use on my hooker shortie headers. ARP makes stainless bolts, but has anybody used a allen key or torx bolt instead? Any recommendations? Also, is the stock exhaust manifold gasket OK for the header?
Old Sep 16, 2004 | 09:41 AM
Bud M's Avatar
Re: which bolts for my hooker shorties?
I'm running Stage 8 locking bolts with anti sieze and Earls gaskets with those headers. No problems. Stage 8s allow you to use either a wrench or an allen wrench.
Old Sep 16, 2004 | 10:08 AM
"White Knight"'s Avatar
I suggest using those locking type that if they loosen a little the have a thing that hits the primary tube and stop it from loosening anymore. Also use anti-seize on them it will keep them from freezing up in there and also keep them from vibrating loose. Also if you are going to use one of those aluminum or crush type gaskets make sure you crush the gasket down not just torque to spec. (something Mr. Goodwrench doesn't know) Long story.......
MDZ28
Exhaust System
Apr 29, 2015 07:44 PM
maybe2fast
Mar 16, 2015 09:45 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
smacz28
Aug 6, 2002 01:51 PM
ferraricameron
Jul 29, 2002 07:46 PM
