Blue smoke after cam install
Old Oct 21, 2004 | 11:19 AM
HungryT/A's Avatar
Hi guys!
My engine is blowing a thick cloud of smoke at idle after a XE 233/239 cam install. Before the cam change there was no blue smoke at all, car has 46k miles.
Why is my engine burning oil at idle?
I have unplugged the PCV tube from the TB, but it's still smoking.
I haven't replaced the valve seals when changing the springs, I thought it will be fine with stock 46k seals. Does the increased valve lift immediately destroy the stock seals?
What could it be , please help!
TIA,
Old Oct 21, 2004 | 01:27 PM
sssalah's Avatar
Re: Blue smoke after cam install
It is most likely the seals. I had the same problem, checked compression and it was good, so replaced the seals and smoke stoped.
Old Oct 21, 2004 | 01:40 PM
HungryT/A's Avatar
sssalah, thanks for your reply!
What type/brand valve seals are you recommending?
Old Oct 21, 2004 | 03:05 PM
madwolf's Avatar
I just used GM seals when I did my spring install. They worked perfect.
Old Oct 21, 2004 | 03:46 PM
HungryT/A's Avatar
Thanks Ion!
Old Oct 21, 2004 | 03:55 PM
The Cartel's Avatar
yep definetly the seals. Viton valve stem seals are pretty much the new standard in seals. I highly recommend.
Old Oct 21, 2004 | 03:58 PM
WS Sick's Avatar
I'll throw my 2 cents in as well and say seals.
Just use the factory positive replacement ones.
Old Oct 22, 2004 | 07:11 AM
HungryT/A's Avatar
Another vote for GM replacement seals...Thanks for your input!
Old Feb 27, 2005 | 08:06 PM
remaxracer45's Avatar
can these be changedd out without pulling the heads?
Old Feb 28, 2005 | 11:46 PM
HungryT/A's Avatar
Definiately, just have to pull the springs.
Jan 23, 2015 01:13 PM
Noenav
Dec 6, 2014 07:35 PM
Dec 4, 2014 11:56 AM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
