Oxygen censors
Old Feb 27, 2005 | 09:50 PM
Daniel6718's Avatar
Oxygen censors
ok heres my question...i have a 94 z28 and my o2 censors are what my mechanic called lazy...they dont react wuickly anymore and its causing a bad backfiring and a ses light to come on...
instead of putting o2 censors back in can i put simulators??? is it bad or what will theis cause???
i though u had to have the front 2 o2 censors on any z28 to read amounts of gas needed??? or is that controaled by maf or what??? i know you can get o2 simm for the rear on an obd2 car but what about obd1 qith only 2 o2 censors???
and with the bad o2 censors and beckfiring after 500 miles do yall think my plugs are bad???
Daniel
Old Feb 27, 2005 | 10:03 PM
Zachz28's Avatar
Re: Oxygen censors
O2 Sims are for the rear o2s only (on 96+ cars). The rear O2s measure your exhaust to see if the cat is working but if you remove the cat these 02 will set a code thats what the sim is for. As for the Front O2s (the ones your talking about) these read the amount of oxygen in the exhaust to see how well the car is running and the cars computer corrects accordingly so if theres are bad then the car will run bad. Thus you cant simulate these. New ones are like 70 ish?? for bosch and are faily easy to replace
Old Feb 27, 2005 | 10:05 PM
Re: Oxygen censors
I would recommend AC-Delco O2s if you need them.
Old Feb 27, 2005 | 10:06 PM
Randy L's Avatar
Re: Oxygen censors
Not sure if you have a pre-cat and post cat O2 sensor setup like my '97 Z, but I've read and have been told that the pre-cat O2 sensors are critical for the fuel injection engines. You can wire up sims for the post-cat sensors, but NOT the pre-cat ones. I did a price check on some sims and they are as expensive as the sensors themselves.
I have also found out that the post-cat sensors only check the efficiency of the cat and do not affect the driveability of the car/engine.
Old Feb 27, 2005 | 10:30 PM
Daniel6718's Avatar
Re: Oxygen censors
where is a good place to get these ac delco shoebox???
autozone is 115 and so is o reilley
gm parts direct are only 35 a piece so there 70 thats what i was going to get?? or this a bad idea
i dont wanna spend more than that really
DAniel
Old Feb 27, 2005 | 10:41 PM
Daniel6718's Avatar
Re: Oxygen censors
shoebox
from gm parts direct is this the ac delco part you were suggesting???
25312184
thanks
Daniel
Old Feb 27, 2005 | 10:44 PM
Re: Oxygen censors
Originally Posted by Daniel6718
shoebox
25312184
thanks
Daniel
That's the correct number. If gmpd shipping is too high, use the parts contacts listed on my Tech Page.
Old Feb 27, 2005 | 10:55 PM
Daniel6718's Avatar
Re: Oxygen censors
thanks for the help shoebox...one final question before i hit the sack...so i should email this guy parts@samtaylor.com and tell him the parts i need and where i live i guess??? then he will send me a form or somethin???
thanks
Daniel
Old Feb 27, 2005 | 11:10 PM
Daniel6718's Avatar
Re: Oxygen censors
shoebox...just email this guy with the parts i need and my location...i needa do this tonite i need them by like this weekend hopefully
thanks
daniel
Old Feb 27, 2005 | 11:18 PM
Re: Oxygen censors
Give either of them a call to order parts.
Old Feb 28, 2005 | 09:40 PM
Daniel6718's Avatar
Re: Oxygen censors
hey shoebox i can get a great deal like 40 bucks for 2 bosche oxygen censors...so why do u like ac better???
just because there a more gm related part...or bosche go bad easy??? or they read bad
o yea called jason today he was cheaper on the shipping but he cost like 7 bucks more then gm parts direct each so it was about the same
Daniel
Old Feb 28, 2005 | 10:46 PM
OBE1 95Z28's Avatar
Re: Oxygen censors
Even though the bosch sensors fit the car, many people haven't had good luck using sensors other than the AC Delcos. Shoebox gives good advise as usual, stick with the AC Delcos.
Old Feb 28, 2005 | 11:18 PM
SS MPSTR's Avatar
Re: Oxygen censors
Ditto.
Old Mar 1, 2005 | 12:06 AM
ShawnMacAnanny's Avatar
Re: Oxygen censors
I just ordered a set of Walker O2 sensors from Ebay for $102. They looked to be a better design to me.
Has anyone used these before?
Here is a pic i took of one
http://home.earthlink.net/~shawnmaca...s/walkero2.jpg
Pwilson59
Sep 3, 2015 08:47 PM
Jmj93z28
Jul 8, 2015 06:58 AM
Jon in SD 97Z
N2O Tech
May 13, 2003 04:13 PM
jer4251
May 12, 2003 12:11 PM
busta9876
Jun 28, 2002 02:22 PM
