Blue Fel-Pro oil pan gasket help
Old Mar 4, 2007 | 08:58 PM
wrd1972's Avatar
I have the blue Fel-Pro oil pan gasket. I used Permatex 1B RTV on the corner joint like others suggested.
I pulled the oil pan back off to address an main stud issue and I noticed that the RTV does not stick to the blue gasket at all. The instructon state to not use RTV at all.
Is there a selant that works better with ths gasket or should I just skip the sealant all together.
Old Mar 4, 2007 | 09:45 PM
LenT1's Avatar
I would like to know also as I just put my engine together and im using the same gasket. Engine is still on the stand but I did not use any kind of sealent.
Thanks guys.
Old Mar 4, 2007 | 09:48 PM
mdacton's Avatar
I use the ROL gasket and I also use the grey permatex (import type) on the corners. works good
maybe try the grey permatex....I started using it a few years back and thats all I use now....works better than all the other stuff.
On the ford stuff I never use anything....I personally don't like the blue fel-pro stuff
Old Mar 5, 2007 | 09:55 AM
T/A KID's Avatar
Whats the ROL gasket, I have heard of the SBC cork gasket??
Old Mar 5, 2007 | 01:12 PM
mdacton's Avatar
Its the name of the company that makes it...I will try to get a part# later
Old Mar 5, 2007 | 01:19 PM
wrd1972's Avatar
I will try the gray Permatex, that is my favorite too.
Old Mar 5, 2007 | 01:25 PM
mdacton's Avatar
I started using it when "the right stuff" came out.....Its seems to hold up alot better to everything.
I went to a permatex class....got my permatex cert.
Old Mar 5, 2007 | 02:03 PM
seawolf06's Avatar
Congrats on 1,000 posts, mdacton. Can you make a thread on all the common permatex products and maybe someone will make it a sticky?
Old Mar 5, 2007 | 02:07 PM
mdacton's Avatar
man they make alot of stuf.....and I don't type that good
Old Mar 6, 2007 | 10:09 AM
seawolf06's Avatar
I was thinking just the 5 most useful for our cars or something like that. Must have been an interesting class, though.
Old Mar 6, 2007 | 12:08 PM
TQdrivenws6's Avatar
I use the blue Fel-pro gasket and it seals up very well on my car. I just put some RTV Ultra Black on the corners and torqued it. Then I let it sit about 2 days before pouring oil into the engine. Also, make sure you completely clean the mating surfaces since an oil residue will kill adhesion.
Old Mar 6, 2007 | 03:30 PM
snakeatinZ's Avatar
I plan on using the blue fel pro gasket in my rebuild as well. Any luck on that sbc cork part #? I gave up. I dont know which one will work for Gen 2 LT1?
Steve
Old Mar 6, 2007 | 03:36 PM
mdacton's Avatar
cork?
Hold on let me go outside..in the cold.... walk to the shop...get the part# and then I will post it.
Any sbc from 86-87 up will work.....This ROL brand gasket seems to me a higher quality. Once you use the fel pro once its done for.
I have used mine 4-5 times
http://www.rolmfg.com/
OS5836P
86-01 GM truck oil pan set
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
