A better Opti Spark?
Old Oct 22, 2003 | 05:57 AM
  #31
jasons93z's Avatar
Originally posted by BES-383
Please read this thread all the way through,and you might understand.
opti alternative
Ok, i stand a little corrected, but. Since it does only use the opti for reference of the cams position then u should still use it. It doesnt look like it uses it for spark anymore, thats what the packs are for it just uses the opti to tell the packs when to fire.
Old Oct 22, 2003 | 06:00 AM
  #32
jasons93z's Avatar
im not a know it all, im just trying to help. Personally, i know people that still use the opti and they have high revving engines. So i guess im still confused on the problems that you are having.
Old Oct 22, 2003 | 06:03 AM
  #33
BES-383's Avatar
Now read this thread all the way through.
Its the high RPMs that makes the rotor fly apart. It is not made to spin over 6,000.
Yes the conversion stops opti failure do too the high votage but not over spinning, People with the conversion are still replacing the opti cap, which houses the rotor.
Old Oct 22, 2003 | 06:06 AM
  #34
jasons93z's Avatar
I stand corrected. I guess u all are screwed , but as i said i know a couple of friends with H/C combo on there lt1's and rev up close to 7k with no problems.
Old Oct 22, 2003 | 06:08 AM
  #35
BES-383's Avatar
Get them to tell their secrets then.
Old Oct 22, 2003 | 06:26 AM
  #36
jasons93z's Avatar
no secrets
Old Oct 22, 2003 | 07:41 AM
  #37
Fastbird93's Avatar
Well, this is definitely a good thread. It's answered a couple of my questions, and has saved me from dropping too much $ on a dynaspark, especially when I found out they aren't warrantied for a race application. I'm quite positive my stumbling trouble is stemming from a bad opti (with less than 1500K miles) and like someone else said, it starts to break up passing through 6000 RPM. Keep this going.
On another note, I'm starting to think it's just hit or miss on the opti. When I bought my car, it had the original, and that lasted until my newbie at the time self powerwashed the motor. That was at about 85K. The second was flawless, but this first afte the vented swap has crapped already.
The LTCC seems like it would be the way to go, but there's still the problem of having the opti rotor flying apart. Maybe a Dynaspark in conjunction with the LTCC??? But who wants to spend that kind of cash?
Old Oct 22, 2003 | 08:17 AM
  #38
Drag Bear's Avatar
Yes you can spin the Opti 7000 in most cases with no problem in street cars because they are not in that range of over 6800 for very long. And even in my case of a full race LT1 that lives 90% of the time over 6000 I have a very low failure rate. The 2 that I lost were over 2 years old. I switch them back and forth when I am having problems just to make sure the Opi is ok.
BUT!!! in my case, the threat of it breaking is very high. I might get away with it all year or like 2 weeks ago take me out of a big race. I allways carry a spare but during elimations I might not have the time to change it.
PS: Hey guys! I respect every ones opion even if I don't agree with it. I want to hear from every one that has one because I find that I can take bits of info from eveyone and in most cases fix my problem. But when people get insulted for it, they tend to not want to help and I think this hurts the forum and what it is designed to do.
Please lets try to help each other, Rick
jmadoll
Jun 10, 2015 04:41 PM
beltrunner
May 17, 2015 10:18 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
DTK
Aug 14, 2002 06:14 AM
