Best way to clean deck surface?
Old Nov 11, 2004 | 01:32 PM
Mullet Z28's Avatar
What's the best way to do this? Just some brake cleaner and a rag? The head gasket isn't stuck to the block or anything, but I way to get a good seal.
Old Nov 11, 2004 | 03:02 PM
TransAmGT94's Avatar
Re: Best way to clean deck surface?
The best way is to just get the block decked by a machine shop. Other than that just clean it up the best you can.
Old Nov 12, 2004 | 12:23 AM
Dave88LX's Avatar
Use a razor scraper, or puttyknife, or a combination of both.
Don't use the razor blade on the heads though, it'll dig into that aluminum.
Old Nov 12, 2004 | 09:08 AM
rskrause's Avatar
Moderator
If there was no problem with the seal before, there shouldn't be now. So follow the suggestions so far in that case. If there was an issue before and you supect the deck isn't flat you can measure with a machinists straight edge if you have access, or just take it to the machine shop for a quick cut.
Rich
Old Nov 12, 2004 | 10:07 AM
OBE1 95Z28's Avatar
Don't use a scotch brite pad as the debris can get down pass the rings and cause damage.
2QUIK6
Sep 17, 2016 02:31 PM
HibachiZ28
Nov 6, 2015 12:53 AM
bunker
Aug 21, 2015 10:21 AM
alphaauto
Jul 26, 2015 04:40 PM
