Best type injectors for LT1 stroker street engines. Ex. Bosch or lucus type.
Old Jul 22, 2004 | 07:53 PM
93SS's Avatar
Which design works best for idle quality, spray pattern, staying clean , etc. for large LT1 street stroker engines for touring purposes. No Drag racing on strip. Thanks.
Old Jul 22, 2004 | 08:03 PM
Re: Best type injectors for LT1 stroker street engines. Ex. Bosch or lucus type.
Moving to "LT1 Engine Tech".
You might want to mention what kind of HP levels you are planning on, and whether you will be using a stock PCM or an aftermarket ECU. That might affect the answer.
Old Jul 22, 2004 | 08:57 PM
93SS's Avatar
Thanks for pointing out some other factors. Car is a 93 Z-28 with factory ECM. Power levels from 500-550 fwhp. 4L-60 auto trans extreme duty with 2600-2800 stall. This will be a semi daily driver type car. No strip drag racing planned. To be a touring type car . Thanks for any info on injector types and reason. Looking at 36-42 lb injectors.
Old Jul 22, 2004 | 10:15 PM
Dave69Z's Avatar
Just curious...what do you have against Bosch or Lucas?
Old Jul 22, 2004 | 11:10 PM
93SS's Avatar
Not anything. The ex. was for example. I wanted to see which one is better in LT1 use between Bosch and Lucas. Thanks for for replies.
Old Jul 23, 2004 | 12:03 AM
Dave69Z's Avatar
Gotcha...
I have 38lb'ers from PTE pretty happy with them. I got them on sale though and they are a bit higher now, but still not too badly priced.
PTE 38lb Injectors
Dave
Old Jul 23, 2004 | 12:31 AM
93SS's Avatar
Thanks Dave. Those PTE injectors are disc type. Probably like the lucus type.
Old Jul 23, 2004 | 02:40 AM
1 Nasty Bird's Avatar
whats wrong with some good old ford motorsport injectors, other then they have a ford symbol on the box.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
spearous
Jan 12, 2015 11:03 AM
