Best Methods For Changing Passenger Spark Wires
Old Jun 24, 2003 | 09:10 PM
AENIMA95z28's Avatar
Got my manifolds off and waiting for header arrival, in the mean time i will change Plug wires, So - what are the Best Methods For Changing Passenger Spark Wires. I dont think im gonna be able to do this without pulling the Ac Compressor Pulley, is there any way around this?
Old Jun 24, 2003 | 09:18 PM
Z95m6's Avatar
Are you going over the top? if not don't route them in the stock location i wasted 2 hrs putting taylors in the stock location. Doing over the tops to 30 mins or so. Much easier to route them and to replace them if they get burnt.
Old Jun 24, 2003 | 09:20 PM
96 WS6's Avatar
On the passenger side I tore out the little plastic bracket that makes a 90 degree turn under the power steering pump and zip tied them in place, much more room that way. Route them from the opti up through the crevice between the AC compressor and the power steering (where that plastic bracket was) and then to the plugs. I tried to keep them all under the hard A/C line to prevent them from bouncing and hitting the header. Stock routing is the best IMO.
Old Jun 24, 2003 | 09:26 PM
Hmm this sounds like a good idea. Any good methods for gettin those plug wires off the Opti, its SOO freakin cramed!
Old Jun 25, 2003 | 05:23 AM
revtime's Avatar
Gettin em off is easy. Gettin em back on is the hard part, that bottom one on the passenger side is a finger breakin b**ch.
I had to do some creative routing on mine but did not go with the OVC set up cause I HATE making my own wires. I have MSD 8.5s and the last 2 on the driver side I did mount ovc sort of, I did not have room to go underneath the headers. The passenger side I routed down and through the motor mount. Use zip ties liberally and you should not have probs.
Old Jun 26, 2003 | 01:31 PM
should i bother wrappin the wires with heat tape ?
Old Jun 26, 2003 | 03:03 PM
If you have the exhaust manifolds off, it should be a breeze. I never took anything off the front. Did them one at a time. The front was tedious, but I didn't think it was that hard.
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
