Best and lightest damper available for the LT1
Old Nov 26, 2003 | 07:59 AM
Highlander's Avatar
As the title says.. I want to know the lightest front damper I can possibly fit in there... My engine is neutrally balanced...
Old Nov 26, 2003 | 08:20 AM
rje's Avatar
rje
I got the LT1 version from fluidamper and have spun mt engine to 7200 rpms with no problem.
Randy
Old Nov 26, 2003 | 08:22 AM
Highlander's Avatar
But how light is it???
I have an Al flywheel and I think I will be getting an ACPT, so that should be a good way to complete the kit.. I am not looking to rev that high, but I want to make the engine rev a lot lot faster even if I dont get more HP.
Old Nov 26, 2003 | 09:05 AM
The ATI Catalog shows part numbers for light weight aluminum shell and aluminum hubs for F-Body LT1's. The aluminum shell saves about 2# and the hub saves about 1#.
Old Nov 26, 2003 | 09:48 AM
J's 82's Avatar
I have the ATI damper on my car, needed the vette version because of my accessory layout..
I did notice a difference in the engines ability to rev..
As for quality the piece is very nice, though if fluidampr had made one for my application I would of gone with that to save some coin...
Old Nov 26, 2003 | 10:13 AM
zhevy-1's Avatar
To answer your question, the Fluidampr is heavy. It's about 13-14lbs. I weighed myself with it on my home scale. That's why I say it's 13-14lbs.
Old Nov 27, 2003 | 11:11 AM
arnie's Avatar
The best won't be the lightest. Best and lightest is a contradiction of terms, AFAIC. It's responsibilities are not the same as a flywheel.
Old Nov 27, 2003 | 07:27 PM
Highlander's Avatar
My engine is neutrally internally balanced.. and I use a stock balancer with none of the holes filled in...
Old Nov 27, 2003 | 07:30 PM
InjectedSS's Avatar
WORD!
I agree, FluiDamper here, heavy as a **** but SAFE for the engine
Old Nov 28, 2003 | 12:55 PM
You're going to find that the ATI vs. Fluidampr arguement is never-ending. I've been using the ATI on a 7K+ rpm engine for over 3 years. This 3,900# car made 1,125HP and ran 9.04@155mph, turning well over 7K rpm with the ATI. Madman ran the ATI....
Can't be all that bad......
Old Nov 28, 2003 | 01:18 PM
Larnach's Avatar
Your best bet for getting an engine to rev quickly, and when I mean quickly, I'm talking like idle to 6000rpm in about .250 of a second, thats quickly. Your gonna need to reduce your rotating compenents weight, and your dampner is not the ideal place to remove the weight from. With our serpentine systems, there is a lot of stress placed on that compenent, plus the job of a dampner/balancer on a cross fire V8 is quite important.
Too get the weight down start off with a lightweight crank, rods, pistons, lightweight flywheel and clutch... unfortunatley streetability suffers quite a bit from the lightweight clutch... go get a tilton if you don't care about that, that'll make your car rev quickly Also the amount of torque has a direct relationship to the rotating components weight on how quick it will rev.
Old Nov 28, 2003 | 02:27 PM
LPE Z convt's Avatar
I have a question will FluiDampers work with a stockbottom end cars that turn 6600 rpms? Will the damper be good for street use or are the designed for mainly strip use? thanks
Old Nov 28, 2003 | 03:08 PM
arnie's Avatar
'Testimonial' type of info report out of balance conditions result when used in low temp (30*- 40*F ?) environments. Appears the 'fluid' does not remain viscous in cold weather. You are in Indiana, so this may not be a concern, IF indeed testimony of this nature is accurate. Not stating it is, or it isn't, just FFT. I reside in Wisconsin, so 'consider the source', in my decision to go in a different direction. Inquiry with Fluidamper mfr. may shed lite on the matter, or result in an issue stemming from a 'conflict of interest'.
Old Dec 1, 2003 | 08:48 PM
1LEThumper's Avatar
ATI balancer is on my car and I've never had a problem with it. A lot of the racers seem to go with that balancer as well.
Old Dec 2, 2003 | 10:40 AM
WS Sick's Avatar
ATI lightest, the ASP underdrive damp/pully is also very light, kinda inbetweeen my stock one and the ATI. I had the ATI on my 93 and took it off when I sold it, when I bought my 97 it had the ASP on it.
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
