BEST CAM TO GET FOR STOCK HEADS?? please reply
Old Mar 1, 2004 | 11:50 PM
formula king's Avatar
okay i got my full exhuats (no cats) suspension and igniton work done to my car...... next im doing 3.73s and cam.......and i was wandering what is the most powerfull (street car) track proven cam to get on stock heads.....thanx
Old Mar 2, 2004 | 12:05 AM
phrozen's Avatar
from what I've heard cc305 and lt4 hotcam are good choices.
Old Mar 2, 2004 | 12:09 AM
Vendetta's Avatar
the 224 xe cam is also a good choice. it depends on how streetable you want your car to be, and how rough of an idle you want.
Xride's Avatar
Well the 305 does better then the hotcam.
but the 306 does good too with stock heads.
how lumpy do you want to go?
Old Mar 2, 2004 | 12:12 AM
scoobysnax83's Avatar
the problem with a big cam is that you need to rev the engine much higher to get it in its max power range. If you have stock heads, you more than likely have a stock bottom end. Anything higher then 6200-6400 on a stock consistently and you're gonna blow something. I would go with the xe224/230. Hotcam or CC305... preferably the 305
Old Mar 2, 2004 | 12:18 AM
i dont want a crazy cam...i want something nasty and will put out alot of power but for a street/strip car
Old Mar 2, 2004 | 12:20 AM
Xride's Avatar
CC305 is for you then
Old Mar 2, 2004 | 12:23 AM
97Z-M6's Avatar
i recomend this one it diped into the 11.9x on stock heads.
847
ghf
Old Mar 2, 2004 | 12:33 AM
better yet ,which cam is dyno proven for most hp gains
Old Mar 2, 2004 | 12:36 AM
Daryn95Z's Avatar
ex 224/230. Really good street/strip cam just a little bigger than the cc305.
Has good low end torque and pulls to about 6200.
Also if you want a little lope, this cam sounds really nice with good exhaust.
Old Mar 2, 2004 | 03:35 AM
simple's Avatar
Crane 210/224, do a search on here under username "Frank95z" i think thats his screen name?!
Old Mar 2, 2004 | 05:38 AM
magius231's Avatar
well, the bigger cam like the GM 847 has been proven to produce more power, but you need to take a look at what you are planning...are you going to have bone stock heads forever? How high are you willing to rev it? If your going to get heads eventually go with a big cam to begin with...if not, decide what you can live with as far as rough idle and RPM range, then get the biggest cam that fits your needs. Look at some dyno graphs for various cams and see which one is giving the most area under the curve (not necessarily the most peak power)
Old Mar 3, 2004 | 12:59 PM
okay which cam out of these is track and dyno proven for the most increase in power and times....
xe 224/230
cc305
hot cam
Old Mar 3, 2004 | 01:16 PM
I know I said the CC305 earlier. But I think that XE224/230 is the best choice.
Old Mar 3, 2004 | 03:05 PM
Daryn95Z's Avatar
Power wise I would say ex224/230 puts out a little more than the Hot cam and cc305.
Times wise I have seen people on this board take all 3 of those cams in the low 12's.
