BEST CAM TO GET FOR STOCK HEADS?? please reply
Old Mar 3, 2004 | 11:20 PM
  #31
Daryn95Z's Avatar
If your going to go with the GM 847 I would get a good dual spring set up.(probably .600+)
With the GM 847 being so big and your going to have to rev it pretty high i would also throw in some new lifters. (comp r's)
Old Mar 4, 2004 | 09:06 AM
  #32
faded93bird's Avatar
You would probably see a 6-8 mph increase at the track in the 1/4. that also depends on what your tune and exhaust setup are.
Looking at cam cards for both the hot cam and 305 are almost identical only a 2 degrees more on both lobes and ramp rates are similar too.
Old Mar 4, 2004 | 09:39 AM
  #33
GREGG 97Z's Avatar
Originally posted by FlyBono24
That's what I was wondering..... thanks!!
How much gain can you get from stock heads and basic bolt-ons? (Like the ones I have)
I wouldn't install a new cam until you get headers first. Several people here have installed the hotcam and other similar cams and have not been happy with the results from them on the stock manifolds. You would probably see better results from a good set of headers first then you would from installing a cam on the stock manifolds.
Old Mar 4, 2004 | 10:45 AM
  #34
MonoxideChild's Avatar
I have the 224/230 Cmotorsports setup on stock heads (they suggested it) So, I'd go with cmotorsports on this one ONLY if emissions are not a real big issue.
Mines on a 111 LSA.
so 224/230 536/544 111 LSA
I'm really happy with it, just need to bump on rev limiter up to 6400 RPMs.
Old Mar 4, 2004 | 01:29 PM
  #35
scoobysnax83's Avatar
Originally posted by formula king
okay i got my full exhuats (no cats) suspension and igniton work done to my car......
gotta read, man...
Old Mar 4, 2004 | 01:39 PM
  #36
GREGG 97Z's Avatar
Originally posted by scoobysnax83
gotta read, man...
I was replying to the question by "Flybono24" who does not list headers in his sig.
Gotta read....closer, man
Old Mar 4, 2004 | 01:49 PM
  #37
toegead93's Avatar
As mentioned earlier the Crane 210/224 workes extremely well with stock heads. That will be my next mod along with 1.6 RR. The torque curve of this cam is flat all the way across the graph with stock heads; there are folks running mid 11's with it.
Old Mar 4, 2004 | 02:38 PM
  #38
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Old Mar 4, 2004 | 03:05 PM
  #39
383_BluByU's Avatar
the 218/224 is a dream in my stoker LT1 in the vette..
Old Mar 4, 2004 | 04:02 PM
  #40
GREGG 97Z's Avatar
I kinda thought that.... (like I have the money for a cam anyways)
I meant to say... "What kind of gains will you get WHEN all the bolt-ons have already been applied?" Like shorty headers, cat-back, etc.
With the hotcam kit, a good set of headers, full exhaust and the usual boltons it seems most average somewhere around 320rwhp. Depending on tuning and other factors some make more, some less.
Through the full exhaust mine did 340rwhp/337rwtq. Numbers below were through the open cutout/orp.
Old Mar 4, 2004 | 07:35 PM
  #41
formula king's Avatar
from what i heard the cran cam 210/224 is the best for the stock heads.....ppl have hit 11s on stock heads with that cam
Old Mar 22, 2004 | 09:15 AM
  #42
Berly_BoneStock's Avatar
What about the 230/236 Thats a pretty kick *** cam with a nice powerband.
Old Mar 22, 2004 | 10:58 AM
  #43
SantaCruz163's Avatar
The question is... which emissions LEGAL cam is the best with a set of good flowing heads (260+cfm)?
Old Mar 22, 2004 | 12:20 PM
  #44
truedualws6's Avatar
Crane dynoed the 210/224 with an aluminum headed
LT1 in stock form (exhaust manifolds, etc.) and had
335 HP, a gain of 35 HP over the stock cam with 1.5s.
With 1.6s the gain was 40 HP. This was running through
a full exhaust. This was an engine dyno so you need to
deduct about 15% for rwhp.
If you just want to put in a cam and run everything else
stock, the 210/224 is a good choice. It was designed for
the LT1 in a stock configuration. Since I am sticking with
stock exhaust manifolds it's the best choice for me.
If you are going with headers and/or modified heads then
you should pick a more agressive cam.
Old Mar 22, 2004 | 01:59 PM
  #45
importeater's Avatar
Yea what about that cam.. Thats what I think I'll be using with stock heads..
