Bailey Engineering LTCC setup
Anybode here using this setup? If so how do you like it?
Here a link to the site: http://bailey-eng.com/LTCC.html
There are a few people running the LTCC and they say it is better then the opti, but I think that if youre not running a lot of power it is over kill. It will cost you about 6-700 for everything to get it running.
I am currently running the LTCC box and think the setup is very sweet. I don't have anytime on the setup because I am waiting to have my car tuned. But what I will say is that at idle the car seems to run a whole lot better. The car also fires right up. I will post more info once I have my car dyno tuned.
If you are trying to fight ignition demons (by switching to the LTCC), it would be silly to buy used parts, IMO.
If you need an opti as well, you will be looking at $1,000 for parts. I have not priced new LS1 coils yet. I bet they are very expensive though (300ish).
Ryan
Ryan
If you need an opti as well, you will be looking at $1,000 for parts. I have no priced new LS1 coil though. I bet they are very expensive.
Ryan
Ryan
I believe LS1 coils are around 25.00 a piece - brand new.
price from www.gmpartsdirect.com for a coil for a 98 camaro is $29.86 each, so, 8 x $29.86 is $ 238.88 , which doesn't include brackets , screws , ect.
i actually got ahold of 8 coils on the brackets with the harness attached for only $25
it sounded too good to be true but hell for only $25 even if half dont work i wouldnt be that upset and i was guaranteed they would all work or did so when they were taken off the car. but when you think about it.. LS1 coils should last 8x longer in theory than our coil because they only fire once/cylindar unlike ours which fires for all 8 every time. given that id guess one LS1 coil should last at least 150k miles.
. I'm only half joking when I say that GM probably built some parts to break regularly.IDOXLR8 - Not as bad as I thought, but still a pretty penny to build the system from the ground up.
Ryan
Originally posted by got_hp?
i dunno about that kit, but i know a few guys that are doing it on their own, for much cheaper..............hell, even supra guys are using LS1 coils now.
Those darn supra guys.
I personally find the LTCC setup to provide a smoother idle, with a slight improvement during cruise conditions. Expect the setup to be more dependable, with less potential problems in wet conditions compared to oem setup. This along with stronger high rpm/high cylinder pressure spark.
My first setup has been on a daily driver since last fall.
