Bad Problems
Old Apr 26, 2008 | 10:47 PM
DustinMcGowan's Avatar
Bad Problems
Hey guys my buddy has a 94 z its acting like its out of gas or is not getting fire it will start but will barley run the cataltyic converter is glowing red but was replaced just a year ago. What do you all suggest be the first thing i try to fix the problem? Keep in mind that this camaro is completly stock
Old Apr 26, 2008 | 10:57 PM
ss.slp.ls1's Avatar
Is it glowing at the headers too, or just the cat? Is it backfiring a lot? If the exhaust manifolds are glowing, it sounds like and ignition problem, with unburnt fuel hitting the primaries and burning.
To be sure, test everything.
Opti: http://shbox.com/1/4th_gen_tech2.html#opti_test
Coil: http://shbox.com/1/coil_testing.jpg
Fuel: http://shbox.com/1/4th_gen_tech2.htm...essure_testing
Thoroughly check for burnt wires, check for fouled spark plugs.
Post up your results.
Old Apr 26, 2008 | 11:07 PM
The manifolds where not glowing but it was backfireing alot and it would seem to clear up and then i would turn the car off and it was a repeat. Pluse the car would idle bad with smoke coming from back of motor.
97Z28Muscle
Feb 6, 2015 10:44 PM
Amshnock
14
Jan 18, 2015 11:47 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
slothgrant
Aug 22, 2002 03:01 PM
jp2002ls1
Jul 22, 2002 04:18 PM
