Bad night at the strip
Old Feb 9, 2005 | 12:08 PM
  #31
ShawnMacAnanny's Avatar
Re: Bad night at the strip
check your EGR.
IT IS YOUR EGR. I Just thought about it. If that gets stuck open it will cause your car to stumble and will throw codes. Try to move the valve with you hand. Better yet just remove it and clean it. It's right on the back of the intake. It has two 13mm bolts holding it on. Should take maybe 10minutes to do. The extra exhaust pressure is what caused this to stick open. It's your EGR.
Old Feb 9, 2005 | 01:33 PM
  #32
Frozen96z28's Avatar
If it isnt your EGR valve, Id suggest hooking up a fuel pressure guage, and see what your fuel pressure is doing when you floor it.
Old Feb 9, 2005 | 03:16 PM
  #33
oneslowz28's Avatar
ok im going outside to do that now. btw who is the guy on here that will reprogram the ecu for cheap becuse i think now im going to remover the egr and air stuff all together
Old Feb 9, 2005 | 03:24 PM
  #34
If your car is OBD1 wont you wont have to worry about it but you said you had rear 02s so you much have obd2. Ion from Madz28.com can do it or Brian from PCMforless.com can do it.
Old Feb 9, 2005 | 03:28 PM
  #35
oneslowz28's Avatar
thanks. where is it located again i l,ookd and didnt see it
Old Feb 9, 2005 | 03:35 PM
  #36
http://shbox.com/1/egr1.jpg
Old Feb 9, 2005 | 03:59 PM
  #37
InsuranceGuy's Avatar
Opti! Opti! Opti!
When my original Opti failed, I could stomp the accelerator and it would
go up to about 3500rpm max.. If I gently pressed the accelerator I
could get it to rev to about 5000rpm. GM replaced the Opti under
warranty and all was well for about another 30K miles.
Emil:93Z,383,Vortech,NOS
Old Feb 9, 2005 | 04:16 PM
  #38
oneslowz28's Avatar
ok heres a pic of my egr sylnoide <sp> and it looks like there is a line missing on the back (left) side if it
egr sylnoide
Old Feb 9, 2005 | 07:44 PM
  #39
link doesnt work
Old Feb 10, 2005 | 09:26 AM
  #40
oneslowz28's Avatar
imagestation wont let outside viewers view it and i dont know anywhere else to host them
Old Feb 10, 2005 | 10:27 AM
  #41
ShawnMacAnanny@earthlink.net
Just email it and i'll stick it up on a webpage.
Old Feb 10, 2005 | 01:10 PM
  #42
oneslowz28's Avatar
photo sent
Old Feb 10, 2005 | 03:01 PM
  #43
http://home.earthlink.net/~3.8/siteb...ctures/egr.jpg
I'm not exactly sure, i havent lookedthat closely at my EGR
Old Feb 10, 2005 | 04:55 PM
  #44
oneslowz28's Avatar
anybody else wanna tske a stab at it?
Old Feb 10, 2005 | 09:15 PM
  #45
oneslowz28's Avatar
bump
