Autolite ?
Old Feb 19, 2015 | 06:13 PM
blac94Z's Avatar
Autolite ?
My dad told me to change my plugs to autolite instead of the champion plat i have in it now.
My question is what type of autolite should i run ?
Old Feb 19, 2015 | 07:04 PM
Re: Autolite ?
Most people seem to run NGK TR55 in "stockish" LT1's. The iridium plugs seem to provide good results, and very long plug life. What advantage does your dad feel the Autolite plugs offer? Nothing wrong with them.
Old Feb 19, 2015 | 09:00 PM
8cylinders>4's Avatar
Re: Autolite ?
My car didn't seem to like the champions when I had them years ago when my engine was close to stock. Switched to TR55's and have used them ever since TR6's now I guess, but Im far from stock.
If it runs good and you still have the stock manifolds (harder to change plugs) then I would probably leave them in.
Old Feb 20, 2015 | 11:46 AM
blac94Z's Avatar
Re: Autolite ?
INJUNEER
IM NOT SURE WHY MY DAD TOLD ME TO RUN AUTO LITE
AND WHEN I TOLD HIM EVERYONE ON THE BOARD RUNS NGK
HE STATED THOSE ARE GOOD PLUGS TOO SO I GUESS ITS MORE OF A preference
then a need
8cylinders>4 YES I NEED TO GET RID OF THESE CHAMPION
PLUGS I THINK THERE FOULING ALREADY AFTER A COUPLE MONTHS
AND ITS NOT THAT HARD TO CHANGE MY PLUGS WITH MANIFOLDS AND I DO THEM ALL FROM THE TOP
IN ABOUT 15 MINS I DID HEAR ON THIS SITE A COUPLE PEOPLE SAY WHEN YOU
PUT HEADERS ON YOU HAVE TO DO TOP/BOTTOM
what gap should i gap them too ? i have them at .45 right now
Old Feb 20, 2015 | 02:23 PM
Re: Autolite ?
Did you use standard, platinum or iridium plugs?
Old Feb 20, 2015 | 04:19 PM
blac94Z's Avatar
Re: Autolite ?
standard i think but i told the Autozone guy plat.
Old Feb 20, 2015 | 06:29 PM
Re: Autolite ?
That will determine the recommended gap.
Nothing wrong with Autolite, I use them with the NA and small shot tune. And a very cold Champion racing plug with the 300-shot. The plugs and gaps were recommended by the guys that built and dyno tuned the engine, using those specific plugs. But with a "stock"/bolt-on/N2O engine, I ran NGK TR6's.
Old Feb 20, 2015 | 09:52 PM
Re: Autolite ?
15 Minutes!! that's pretty hard to believe, you must have ninja hands then. The number 2 plug is pretty tough to get at with the alternator installed..
With headers I get 1, 3, 7, 6, and 8 from the bottom, the rest from the top.
anyway, with the NGK's they came pre-gapped at .044" and I always had good luck doing that.
Old Feb 23, 2015 | 04:29 PM
blac94Z's Avatar
Re: Autolite ?
I dont know if it makes a difference but i dont have the air pumps on my car so its not alot of stuff in the way with my 3/8 drive
StealthElephant
3rd Gen / L98 Engine Tech
Oct 24, 2003 04:39 PM
96z
Sep 29, 2003 10:38 AM
96z
Sep 25, 2003 09:33 AM
2000zee28
Jun 8, 2003 09:11 PM
KASR_Z28
N2O Tech
Jul 22, 2002 01:40 PM
