Anyone running an X-pipe setup?
Old Jun 11, 2003 | 08:41 AM
Fatsix's Avatar
starting to mod my friends car and am looking at running an x-pipe with a set of Jet Hot or Hooker LT's. Do any of our vendors sell a kit of the mandrel bent peices? I have an X that was supposed to go on one of my cars
Old Jun 11, 2003 | 08:50 AM
LT1ponykilla's Avatar
Just do a search on this. Im sure you will find more info on this and some pics of the X pipe setups.
Old Jun 11, 2003 | 08:55 AM
Fatsix's Avatar
i did, found all y-pipe setup stuff.
Old Jun 11, 2003 | 09:12 AM
Chris'SS #2152's Avatar
Re: Anyone running an X-pipe setup?
Check out Speed Inc. They have x-pipe systems on their cars.
Old Jun 11, 2003 | 09:41 AM
Lost's Avatar
Do a search for "true duals" if you want to see how people have done an x setup. If you're planning on welding it yourself (highly suggested) then I don't think you need a kit.. just find someplace local that sells mandrel bends (or order a few) and use them as you go. Really, there are not that many bends, most of the bends are used between the collectors and the x... after the x it's pretty much straight back.. I used two bends and the end to turn the piping out at the rear wheels and downward.
HTH
Old Jun 11, 2003 | 10:07 AM
Fatsix's Avatar
yep i searched true duals right after i posted that. Which style flange do the Jet Hots use? Hookers use a 3 bolt collector no? Thats going to be the only part that will present a problem, i have a pretty good idea of what has to be done after looking at the y pipe on my car.
Old Jun 11, 2003 | 10:27 AM
ltlhomer's Avatar
Yep 3 bolt collector on the hooker lt's. I have a 3" universal xpipe from Summit into two bullets and dumps before the axle and it sounds awesome. Badass at idle and it screams at upper rpm's.
Old Jun 11, 2003 | 10:36 AM
Fatsix's Avatar
anyone know what the Jet Hot Lt's use? slip?
Old Jun 11, 2003 | 11:15 AM
OrangeAndWhite's Avatar
Jet Hots are almost identical to hookers, use same collector etc
Old Jun 11, 2003 | 11:47 AM
allmotorta's Avatar
sounddomain.com/id/orangetransam. Scroll down, you'll see my true dual setup.
Old Jun 11, 2003 | 11:59 AM
Fatsix's Avatar
did you have to bend the pipe much up where it connects to the header, around the floor board and what not?
Old Jun 11, 2003 | 04:03 PM
allmotorta's Avatar
I didn't have to bend or bang up anything. It fit right in there and bolted up fine, doesn't rattle etc....
Old Jun 16, 2003 | 11:01 PM
sorryofficer's Avatar
That looks really easy, too easy.
How hard was the header install for ya?
Old Jun 17, 2003 | 01:58 AM
allmotorta's Avatar
ehh, wasn't that bad really. No big deal. But then again, both my headers slid right in from the bottom, most people have to jack their motor up, I didn't..i got lucky i guess
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Jun 23, 2016 08:42 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
sleeperZ96BT
Sep 5, 2002 05:45 PM
