anyone have a 54mm throttlebody?
Old Dec 2, 2004 | 07:45 AM
flusz28's Avatar
any difference in performance from my 52 too a 54mm? thanks
Old Dec 2, 2004 | 08:04 AM
kamba93lt1's Avatar
Re: anyone have a 54mm throttlebody?
I run one. I never had a 52 though. I just was a cam only car with a stock thottle body. I put the 54mm on with a couple of other mods. The car went from 12.20's to 11.80's. I also changed gears and trans though. I would say it depends on your setup to notice the change from a 52 to a 54. If the motor needs more air then you will notice if not there will be no difference.
Ken
Old Dec 2, 2004 | 10:05 AM
skibbe_96z's Avatar
Your manifold only has 52mm inlets. If you wanted to use a 54 you would need to bore your manifold to get the gains. Plus, a bigger throttle body isnt going to help you any enless you have mods. I would say jump up to a 52mm throttle body when cam is installed among other things if you want to see some gains from it. It isnt needed but you will see better gains. I dont know what kina mods you have but I would say if you dont have headers and CAI or anything like that, I would put the money to better use. That is my opinion.
Old Dec 2, 2004 | 02:15 PM
1SlowFormula's Avatar
Sorry to hyjack this thread, but who sells the 54mm TB? I remeber looking into TB's a while back and all I saw was 52 and 58
Old Dec 2, 2004 | 02:23 PM
kamba93lt1's Avatar
Arizona Speed and Marine make the 54mm. They rate it at 900cfms.
Bought mine through Thunder Racing for I think 479.00
Ken
Old Dec 2, 2004 | 03:40 PM
Z95m6's Avatar
no real point in going with a 54 when you can get a 58 for the same price and get even more flow.
Old Dec 2, 2004 | 03:44 PM
skibbe_96z's Avatar
you wont get more flow enless your manifold is bored to mach....
52mm is the best enless you have a real radical set-up.
Old Dec 2, 2004 | 03:51 PM
Z95m6's Avatar
I am well aware of that. It only takes 30 mins to port the intake at home for the TB at least thats what i did on my 58mm .
Old Dec 2, 2004 | 04:01 PM
zhevy-1's Avatar
I have an ASM 54mm TB. I've also had a Holley 52mm. I like both.
Old Dec 3, 2004 | 09:46 PM
flusz28's Avatar
well i have of course the 52mm - midlength headers-no cats -loud mouth exhaust. s-trim blower with 9-10 psi,having the heads ported-1.6 rockers/springs, maybe getting a blower cam that has a idle close to stock. have a bunch of other boltons but this gives ya the idea whether the 54mm would even do anything for me? could i port my 52mm into a 54?
MAKQSIK
Parts Wanted
Jun 11, 2015 04:30 PM
JeffsWorld
Nov 21, 2003 07:55 PM
ZDriver96
Aug 19, 2003 11:01 AM
95z28 -quicksilver
May 12, 2003 09:56 AM
kmc_audio
Oct 1, 2002 09:34 PM
