Using ARP main bolts while keep windage tray
Old Feb 3, 2004 | 07:40 PM
v7guy's Avatar
How do you pull this off? Is the only way to do it using the stud kit for the mains?
Old Feb 3, 2004 | 08:51 PM
Josh-'04 GTO's Avatar
I used ARP studs and still couldn't keep the windage tray. I'm pretty sure you actually need to pirate some studs off a 400 block stud set and combine that with the rest of the standard ARP SBC studs to be able to reuse the tray. Not 100% sure since I bother with the tray. That was two years ago, and my motor doesn't seem to have any oil control issues.
Old Feb 3, 2004 | 08:58 PM
S.J.S.'s Avatar
I with Josh as far as when I rebuilt mine to the stroker. I had clearance issues with the rods anyway so I just killed 2 birds with one stone and got me the Canton oil pan (awesome). It has a built in windage tray.
Old Feb 4, 2004 | 08:11 AM
I bought three new GM studs p/n 12561389 and yes those three were about as expensive as a set of ARP bolts.
Old Feb 4, 2004 | 08:23 AM
TCAL95Z's Avatar
shoebox,
did you use the factory pan and tray?
Old Feb 4, 2004 | 08:55 AM
Originally posted by TCAL95Z
shoebox,
Yes.
Old Dec 4, 2004 | 12:13 AM
Highlander's Avatar
Re: Using ARP main bolts while keep windage tray
How about soldering the tray to the pan?
HectorM52
Jul 30, 2017 11:46 AM
dfarr67
Apr 10, 2015 07:44 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
