Any way to have a quiet valve train with 1.6 rr's?
Old Nov 13, 2003 | 08:59 AM
  #16
ksmyss's Avatar
Originally posted by stereomandan
ksmyss,
What brand are you using?
Dan
they are the crane gold full roller ones
Old Nov 13, 2003 | 10:47 AM
  #17
stereomandan's Avatar
Perry93TransAm,
That is exactly the info I was looking for. So all full rollers make extra noise to a certain extent, and the roller tip rockers were pretty quiet? Those were the Comp Cams roller tipped right? 1.6 ratio?
Any problems fitting a spring under the roller tipped rockers? I'm not sure exactly what spring I would need for the CC502, but the lift is .528/.535 with 1.6 rockers.
Any problems that you see going to 6000 rpm with the roller tipped rockers, or is it a non issue.
Thanks again.
Dan
Old Nov 14, 2003 | 09:10 AM
  #18
Perry93TransAm's Avatar
I had the 1.6s first on the stock cam then later on the cc305 that was in my 93 T/A. I would recommend the stock springs to be upgraded at least to the crane kit. The pressures are decent but good for mild cams. I reved the cc305 w 1.6 comp roller tips to 6500 regularly.
Old Nov 14, 2003 | 09:32 AM
  #19
FastWhiteTA's Avatar
Agreed.
I take mine to 6200+ and don't have any problems w/ the CC roller tipped 1.6 rockers. I wouldn't recommend the stamped 1.6 rockers, I'd at least go with the Comp Cam Magnum 1.6 rockers. They're $100 cheaper than the pros, and still serve a good purpose, and mine are very quiet.
Old Nov 14, 2003 | 01:42 PM
  #20
That is GREAT news. I know full rollers are better from an overall friction standpoint, and maybe some stability, but if the roller tipped rockers hold up to 6200 RPM, then I'm perfectly happy. I'm not going to rev it any higher than that.
They must be pretty good considering that even the stamped stock ones seem to last 150,000+ miles. I know that the stock redline is only 5700, but they still seem to last pretty well.
Do you need guideplates with the CompCam's Magnum Roller Tipped rockers or the Crane Roller tipped rockers? I think I saw self aligning ones, but haven't seen non self aligning.
Dan
Old Nov 14, 2003 | 03:20 PM
  #21
unTAmedLS1's Avatar
My 1.6 pro mags are pretty quiet and they have seen nice rpms like 64 & 6500
Old Nov 14, 2003 | 04:39 PM
  #22
doodad's Avatar
I was very suprised that mine didn't make any more noise at all. I just now hear them for about 30 seconds at a start with the cold weather. I have the LT4 full rollers.
Xiantyl
Jul 21, 2015 05:42 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
GT what?
Jul 14, 2015 10:17 PM
Catmaigne
Jul 14, 2015 05:17 PM
