any A4`s with 410`s
Old Nov 14, 2004 | 03:51 PM
rock1501's Avatar
any A4`s with 410`s
I was thinking of going that route since I am going though the traps at 5200 rpm and am wasting 800 or so rpm.I dont drive the car much other than taking it to the track so I figure I might give it a shot.
I was wondering at what rpm you guys are at when crusing at 55mph in O.D
Dave
Old Nov 14, 2004 | 04:17 PM
madwolf's Avatar
Re: any A4`s with 410`s
55 is about 2100 in A4 with 4.10 gears.
Here's a post for you to check out, another and another one.
Keep in mind that your MPH will probably go down a bit when you switch to 4.10s.
Old Nov 14, 2004 | 05:40 PM
Boost It!'s Avatar
i had 4.10s, but i was revving to 7000 with a 3800 stall and trapping 117 . Made the stall feel better but man did 75 on the highway get old
Old Nov 14, 2004 | 09:11 PM
rock1501's Avatar
I was thinking it would go up since I am only trapping 108-109 at 5200 rpm
Also I figured it would help my 60ft times too cause I bog bad out of the hole with the et streets on.(when I spin abit I get a 1.70 60ft and when I dont spin I get like 1.80)
Old Nov 14, 2004 | 09:23 PM
12SCNDZ's Avatar
I ran this combo for 3 years:
3448# '93 Z
Bone stock LT1 with exhaust manifolds
3200 stall 10.5" converter
4.10 gears
26 x 10.5" Et Streets
I ran 12.82 @ 106 MPH with this combo. The car was extremely street driveable...2300 RPM's @ 60 MPH in 4th gear. It got over 18 MPG with this combination. With the stock engine it was an extremely consistant 12.9 car.
I only swapped to 3.73's when I did the CC305/ported heads, because I was on my 6200 RPM shift lite about 75 ft. before the stripe @ 112 MPH. I was going out the back door after making a 3-4 shift. The 3.73's slowed the car down .3. I'm switching back to 4.10's for the new motor. The 3.73's really suck.
Frank
Old Nov 14, 2004 | 09:33 PM
96m6lt1's Avatar
a few years(97)ago a friend of mine had a set of 4.10s in his(94) a4 ta it would toss you back on the launch but the car spent more time hitting the rev limiter of an un-tuned pcm so he traded it off for a 3.42,much happier.with a tune, converter ,full ex it would have been awesome
Old Nov 15, 2004 | 11:43 AM
rock1501's Avatar
I was all set to do it untill you mentioned hitting the rev limitter.My car is a bracket car and if I hit the limitter I dont understand what would cause that to happen.right now it is st to shift at 5900 and the limiter is set at 6400.:dunno:
Old Nov 15, 2004 | 02:12 PM
madwolf's Avatar
Are you still running the OBDII or did you convert to OBDI?
Who did the tuning?
Old Nov 16, 2004 | 11:43 AM
rock1501's Avatar
Who did the tuning?
I have both.
Thanks for the help guys.I think if I decide to go with the 410`s I should be fine with 108-110 traps
Old Nov 16, 2004 | 04:43 PM
meangrn94ta's Avatar
i'm running 4:10's in my car and i love them as long as its not an everyday car. even then it isnt too bad but the constant hum at about 55-60 mph gets a little old. i put mine in the car with 96,000 on the motor and tranny. i did it over the winter and started bracket racing the foloowing season and ran great. and this season i blew the tranny out but then again the tranny has about 105000 on it now that was with et streets surprised it lasted that long lol.... good luck
Ws6Envy
Parts Wanted
Apr 17, 2004 11:07 PM
92CamaroRS
3rd Gen / L98 Engine Tech
Feb 19, 2004 01:57 PM
Zeueses 97 RamAir
Oct 31, 2003 01:36 PM
MistaZ
Aug 7, 2003 06:33 PM
Sloh_One
Nov 23, 2002 09:23 AM
