Another question about removing heads...
Old Apr 8, 2003 | 06:39 PM
94 CAMRO Z28's Avatar
Red face Another question about removing heads...
The coolant line that runs between both heads on the back, I can't seem to budge the bolts that hold them in. So im thinking of trying to pull both heads out together. There is a group of wires that run past the backside of the driverside head. And a little clip with a bolt into the head holding them in place. I can't seem to get that one to budge either, any tricks?
Aaron
Old Apr 8, 2003 | 07:35 PM
94F1Z28's Avatar
Well i had the same problem and pulled the heads together,make sure you have someone helping you,then i ordered new bolts and i got a better set that are easier to work with(they are a better design and have bigger bolt heads).Also the bolt that holds the wire harness should come out but be patient because there is not alot of room but it should come easy.Good luck.
Old Apr 8, 2003 | 08:22 PM
magnumv8's Avatar
I got on top of the engine compartment to get better leverage, and used the closed end of the wrench carefully making sure it was square on the bolt. It wasnt easy, but I got them both without damaging the bolts.
Good luck
Old Apr 8, 2003 | 08:30 PM
Yea I was inside the engine compartment ontop of the engine using all my might..(well almost) I was scared I was either gonna break the bolt off or the wrench was gonna slip and I would break my hand.
Aaron
sscott
Jan 17, 2015 04:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
pologreen97z
Dec 2, 2014 10:42 AM
97TA-WS6-Con
Sep 5, 2002 02:26 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
