Another 1441 error question
Old Apr 7, 2008 | 12:11 PM
96 mongoose's Avatar
I just replaced my fuel pump unit a couple of months ago. Shortly there after I recieved the 1441 code. I was wondering if I should replace the canister purge solenoid and valve or go back and double check the lines around the fuel tank. Thanks.
Old Apr 7, 2008 | 01:00 PM
Pontiac_97's Avatar
make sure everything is tight. i had that code and it ended up being a loose vaccum hose at the purge solenoid. i ziptied the hose so it would stay tight and the code went away
Old Apr 7, 2008 | 01:09 PM
P1441 sets when the vacuum detection switch on the passenger side valve cover picks up a vacuum in the line from the canister to the purge solenoid, when the purge solenoid is supposed to be closed. Its most likely a problem with the purge solenoid or the vacuum switch. It can be caused by the two lines on the purge solenoid being switched.
Old Apr 7, 2008 | 03:31 PM
Thanks Injuneer. That what I thought just want to make sure. Thanks for the heads up Pontiac_97. I'll have to double check the hoses.
DirtyDaveW
Dec 1, 2016 05:37 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
ChrisFrez
Dec 15, 2014 03:09 PM
jeff94z28
Sep 11, 2002 02:01 PM
slothgrant
Aug 22, 2002 03:01 PM
