Aluminum for Block Off Plates?
I am removing my EGR system and was wondering if I could use standard 1/4 or 3/8 aluminum stock for the plates? Will aluminum stand up to the heat without warping?
Re: Aluminum for Block Off Plates?
might warp if you tighten down on the nuts too much and cause it too bow in the middle? I mean this is If you use a gasket and the gasket "squishes" down tight at either end where the nuts are it might cause a gap in the middle areas because the aluminum is so pliable. make sense?
edit: that's more of a question than a comment
You might want to look at the aluminum block off plate sets sold by SJM Manufacturing. He uses 6016 T6 billet aluminum.
http://www.mycamaroz28.homestead.com/
I used a peice of 12Ga aluminun that I bought, cut out the shape using the flange that was on the hose. I put red rtv on the aluminum then put the flange on top of that then put the nuts back on.
I wasn't necessarily suggesting that you buy Steve's plates (I do have a set though
). Just wanted you to see the specs for the material he used, and perhaps the comments he makes regarding gaskets and RTV. The plates he sells are 1/8" thick.
I have a full set blockoff plates to go on my new intake that are made out of stainless steel (had a contact at a local machine shop that has a laser cutter).
One question.... does anyone know the thread type (size) used for the EGR and AIR fittings on the rear of the intake? The intake I am working on had the studs removed when I bought it.
carguyshu
Jan 22, 2017 11:19 AM
DETROIT_AREA_00_SS
Aug 15, 2002 11:41 PM
