Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Problem with hooker install, how does this go in?
Old Aug 14, 2002 | 03:23 PM
DETROIT_AREA_00_SS's Avatar
Post Problem with hooker install, how does this go in?
The tube that connects into the header is way off for connecting. Here is a pic.
http://manifestation.org/~ill/fs/upl...HEADERPART.jpg
HOW THE F^CK DOES IT FIT?
Can I leave it off with a block off plate on the header? (What codes or any loss in perf because of it?)
Old Aug 14, 2002 | 03:31 PM
cASe SenSiTive's Avatar
Exposed Member
Post
That's the air-pump tube. It's there to get the cats up to temp. No performance loss, but I dunno about a code.
You could try heating it with a torch, and bending it. But I'd just tear off all the air-pump crap and be done with it.
Tom
1997 30th Aniv. SS <<383 Cubes of Nitrous Huffing Power!
1990 Mustang Notchback <<Project... Sold!
2FASST.com <<< Holy s***! It's really here?!?!
Motown Muscle <<< Dedicated to today's musclecar!
"...Now go away, or I shall taunt you a second time!"
Old Aug 14, 2002 | 05:33 PM
QUASAR BLU's Avatar
Cool
Block off the header, and tear the rest of that **** off. As case said, its there for your cats, its supplies them with oxygen at start up. f*ck the ozone.
John
Bright Red 2002 Pontiac Firebird Formula M6
taupe leather - ttops - 6 speed
1995 Quasarblue Z28 hardtop A4 - sold
Motown Muscle a Detroit area performance club for today's musclecar
Old Aug 14, 2002 | 05:47 PM
IrocSS85's Avatar
Post
well, you could fab up some block off plates and take it all off. but then you'd need custom program to eliminate the AIR system. so if you want a reprogram anyways, take if off.
otherwise, bolt on the lowr portion, heat it up and twist/pull it over to the rubber hose. or even get another piece of hose to make an extension to reach the hose.
I deleted my air system even though I dont have my headers on yet. it'll make changing plugs ALOT easier and will cleanup the eng. compartment.
chris
1986 Iroc Z
355, ported camel hump heads,750 holley, 700r4, 10.5 compr., forged flat tops, solidcam .501I .510E, 4gen rear w/3:73 posi, girdle, and disc's, Edel. torker II, shift kit, 3500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd 6al, coil, dist., mallory wires.13.34 @102mph best w/that combo. have trick flow heads and tighter conv. to put in currently.
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
Old Aug 14, 2002 | 06:31 PM
DetroitZ's Avatar
Post
They sell block off kits for the AIR and EGR systems for 30 dollars on LS1.com and LS1tech.com. Some cars throw a code and others don't. You don't need the stuff, they just help with emissions. Also how is the rest of the install going, my hookers should be here any time soon? Are you doing them yourself?
Mike
Old Aug 14, 2002 | 07:08 PM
CamaroSS30th's Avatar
Exclamation
Nick... I take it you don't want those tires anymore?
Jay
Old Aug 14, 2002 | 07:55 PM
Post
Jay,
Sorry for being a d1ck. YES I do want them, just have been so caught up in all this. Email me with your number (I have it somewhere) or you can call me 586-350-6655 and we'll set up a date I can get them.
Again, sorry this isnt the way I do business on here.
-Nick
Old Aug 15, 2002 | 06:33 AM
99Hawk297's Avatar
Post
Mine didn't line up either. Yank that AIR crap out of there. Engine looks MUCH cleaner. If you get a code shoot me an email.
'99 Black Firehawk Convertible, M6
Whisper Lid, WS6 Lower Airbox,
TB Bypass, Ported TB, IRS MAF
TR224 Cam and Comp 918's.
Old Aug 15, 2002 | 08:15 AM
Black Sunshine/ 00SS's Avatar
Post
I had mine deleted also, and just blocked them off.
I get the impression that you aren't looking to do that. Really simple. Most guys use the ones off a 99, because they are bent different. But you can just put it in a vice & SLOWLY bend it to the shape that you want. It does help to heat it up in the bend. If you go to fast, you will break it. I have done this a few times, & it worked out great. Make sure you use a gasket when you put the tube back on.
I got your message, but I'm having problems with my phone, so shoot me an email if you need anything. I'll call you again later, when I get the phone thing figured out. Later.
hchap63@hotmail.com
01/SS, Black A4, TR224/112, ARE stage 2 heads, lid, FTRA, PMAF, PTB, Grott LT, true duals, NGK, ASP pulley, Vig 3200, LCA, poly TAB, Convo pros, ET Streets, 3300 raceweight. Little bit of juice..
Best ET: (All bolt ons) 11.496@116.42 (1.52)
Current best after Head & cam & nitrous:
10.88@124 (1.60)
Motown Muscle King of The Hill winner 6-8-02. Want some? Get some!!
RIP #3 Dirty Dale!!!
Old Aug 15, 2002 | 04:39 PM
Post
http://manifestation.org/~ill/fs/upload/warwound.jpg
That would be one of the many cuts.
Old Aug 15, 2002 | 04:45 PM
derty's Avatar
Post
I got a second passenger side pipe because it's straighter and shorter than the driver side. Might work slightly better. Just try it out with your passenger side one and see how far off you are. I also had to fab up a 6" piece of 3/4" radiator hose to connect it back up. No big deal. I actually should get rid of that crap and loose a little weight in the process.
Old Aug 15, 2002 | 11:41 PM
Post
I am going to make some block off plates and pull out all this extra ****. After that I will delete all of the computer air pump stuff.
Noenav
Mar 1, 2019 07:38 AM
alex5366
Feb 17, 2015 09:07 AM
ModdedNerd
Jan 1, 2015 10:56 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Chrisdude
Jul 24, 2002 02:25 PM
