Alternator plug ins....HELP Gotta get home
Old Jun 12, 2005 | 03:07 AM
LastOfBreed's Avatar
Just helped do my header install tonight and I barely got home before everything started dying. ABS INOP light came on....turn signals stopped working, lights were getting dim, Air Bag light came on, air wasn't working, radio shut off.
I only have the wire connected to the back of the alternator. I didn't take it off so I don't know if it's supposed to have more than 1.
HELP
Old Jun 12, 2005 | 03:13 AM
romoranger's Avatar
Re: Alternator plug ins....HELP Gotta get home
there should be a plug in the bottom of the alternator, and a wire (battery) bolted onto the back. just don't turn that thing tight on there, i made the mistake and broke it. i bought a new alternator and it wasn't that cheap.
Also.....I ended up not using 2 of the mounting bolts for various reasons....they will get put in. Is the case not grounding itself?
Old Jun 12, 2005 | 03:15 AM
romoranger's Avatar
nah, you are ok, i have been running with only 1 bolt holding my alternator in place for like the past 100 miles, that thing sure is in there tight though.
is the batter connected? or is it dead? the plug on the bottom of the alternator needs to be plugged in
Old Jun 12, 2005 | 03:22 AM
That's what I was looking for. I now need to find this plug. All I have now is the red wire from the alt to the battery.
Old Jun 12, 2005 | 03:34 AM
romoranger's Avatar
ok, so is the alternator off the car? basically, when you take the alternator off, directly on the bottom is a plug that is....plugged into it. if you need anymore help of would rather be walked through i can pm you my phone number rather than playing board tag
Old Jun 12, 2005 | 03:40 AM
I'll look for it tomorrow. I was doing everythign in such a hurry that I didn't get it done. Easy enough fix.
Old Jun 12, 2005 | 09:40 AM
swemdog's Avatar
I plugged mine in and it fell out 2 times, its not fun when you start to see your voltage drop 180 miles from home.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
surreybrad
Apr 22, 2015 06:40 AM
eanhl2004
Apr 4, 2015 12:01 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
Gtpguy
Jan 26, 2015 04:50 PM
