All things being equal
Old Sep 6, 2004 | 06:28 PM
z-rated 97's Avatar
Question All things being equal
If a lt1 and a ls1 were both producing the same #'s to the ground (lets say 350hp and 370tq), and were driven by the same person in identical weather conditions (basically all things being equal). What variance will there be in the 0-60, 1/4mi, and trap speed? (if any at all). . . . I ask this because I've read so much about the top end speed of the ls1 motor. If there's a difference, what is the cause/reason(s)? To my understanding all the specs between a 93-97 and 98-02 are the same (except the motor). Is it simply a more efficient motor? Why do so many prefer the ls1? It's definately faster stock but it also costs a few grands more to own one. I'm sure the answer to this can get very technical, but I'm very curious!
Old Sep 6, 2004 | 06:32 PM
RamAir95TA's Avatar
Re: All things being equal
The peak HP and TQ of each motor will determine trap speed and ET. Generally, LS1 cylinder heads flow nearly 18% better than LT1 heads, which is why they really shine in the upper RPMs.
And I think this statement is the oxymoron of the day:
Old Sep 6, 2004 | 06:45 PM
z-rated 97's Avatar
. . . .You're right! . . . . .what I was trying to say was that they both use the same tranny, suspension, wheels/tires, curb weight being about equal, etc.!!!
Old Sep 6, 2004 | 07:02 PM
RamAir95TA's Avatar
Originally Posted by Shackleford
The transmissions aren't exactly the same.
Gearing and internals of both A4 and M6 transmissions are identical. The only difference is the bellhousing.
So...they are the same.
DirtyDaveW
Dec 1, 2016 05:37 PM
BLK1997Z28
May 2, 2015 01:26 PM
Hal Fisher
Sep 14, 2002 09:36 PM
Ryabut98
Sep 3, 2002 11:45 PM
