engine temp gauge
engine temp gauge
ok correct me if im wrong but on my 95 z the pcm reads from the sender in the water pump right and the sender by the #1 cylinder is just for the cluster gauge. if i disconnect the #1 cylinder temp sender to put in my autometer temp sender for my gauge will i get an SES light or check gauges light?
Re: engine temp gauge
You can use it no problem, but I would recommend tapping into the water pump sensor. The coolant temperature in the cylinder heads versus what the PCM actually reads can vary by 20 degrees or more. GM makes a connector/sending unit that can be tapped into the sensor on the water pump so that the gauge on the dashboard matches what the PCM sees.
ro2207
Dec 4, 2014 06:18 PM
