AIR what???
Old Jun 29, 2006 | 08:12 PM
Chevycobb's Avatar
AIR what???
What exactly is the point of having the air pump going to the headers on cars?? what purpose does it serve and how much difference in the emissions is there with it removed??
Old Jun 29, 2006 | 08:22 PM
97Formy's Avatar
Re: AIR what???
It heats up your Cats faster so they can do there job sooner. Other than that they serve no other purpose for emissions on our cars(as far as I know).
Old Jun 29, 2006 | 08:24 PM
Chevycobb's Avatar
Re: AIR what???
so it's not even working all the time? only when the car starts??
Old Jun 29, 2006 | 09:45 PM
Dave89IROC's Avatar
Re: AIR what???
correct, runs for no more then 2 minutes at start up only
Old Jun 29, 2006 | 09:56 PM
Chevycobb's Avatar
Re: AIR what???
well forget that! that crap is coming out...
Old Jun 30, 2006 | 01:22 AM
Randy L's Avatar
Re: AIR what???
Not sure about the '94's but my '97 will throw a code if the AIR is removed. You should consider deleting the code with a PCM tune. I don't think it affects driveability to run with the code though.
Old Jun 30, 2006 | 05:38 AM
Chevycobb's Avatar
Re: AIR what???
yeah Im putting on heads and cam so i'll be getting a tune anyway...i'll be sure to note I deleted them.
If I drive around for a while before getting emissions done to get the cat nice and hot wouldn't it pretty much serve the same purpose? the only visual inpection they do is look for a cat.
Old Jun 30, 2006 | 06:39 AM
Re: AIR what???
93-95 OBD-I does not set a code for the missing AIR pump, as long as there is a good fuse in the circuit.
DirtyDaveW
Dec 1, 2016 05:37 PM
Latronaxe
May 14, 2015 01:23 PM
squarehead
Jan 15, 2015 07:02 PM
95chwagon
Jan 13, 2015 09:19 PM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
