air fuel ratio gauge
Old Apr 19, 2004 | 09:09 AM
Geezer powered's Avatar
On the o2's there's for a 4 wire hook-up, which color is the signal wire?
Old Apr 19, 2004 | 09:21 AM
jeremyferguson's Avatar
I'm pretty sure that most of the time is the purple wire.
Old Apr 19, 2004 | 09:29 AM
I used the purple wire but tis not working, was told its the gray wire
Old Apr 19, 2004 | 02:07 PM
anyone else?
Old Apr 19, 2004 | 02:19 PM
wiked95ta's Avatar
PM Shoebox, he has docs on everything.
Here's something i just found on google.
http://www.prostreetonline.com/pso/i...to/swpaf/2.jpg
I'll check the doc I got with my air/fuel gauge, purple sounds right to me.
Old Apr 19, 2004 | 02:27 PM
Make the connection on the wiring harness, not on the sensor wires.
Driver's side is purple/white stripe, connected to pin C20 (grey connector) on the PCM.
Passenger side is purple wire, pin C8.
The sensor has tan, purple, black and pink wires. Purple is the signal wire.
Old Apr 19, 2004 | 02:41 PM
thanxs injuneer, will try that
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
97ss1826
Mar 13, 2003 11:58 AM
Burn_Out
Aug 18, 2002 08:49 AM
