Need Help!!---dead ignition
Old Apr 19, 2004 | 02:53 PM
DMartin's Avatar
Angry Need Help!!---dead ignition
I just got thru replacing the plugs with NGK's, fired it up and ran the valves, reinstalled the valve covers, and now it wont start. I pulled a plug wire and its definitely not firing. Any ideas? The coil and opti were replaced last year when I went thru the motor. Probably less than 6000 miles on them. Could it be the VATS(?) system? Any help is appreciated. I had to call in late for work. Least to say I'm alittle pissed off.
Old Apr 19, 2004 | 02:57 PM
HBHRacing's Avatar
VATS will keep the starter from engaging and can kill the fuel injectors. so thats not it. it's proabably something simple. you can follow this link to test your system. I would start with the hot fused feeds for everything in the tets
http://mainstreamtopics.com/forum/in...p?showtopic=78
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
