AIR and EGR delete?
Old Apr 11, 2008 | 03:57 PM
  #16
On your 96 it will throw multiple codes... no EGR solenoid, no EGR flow, AIR flow to left and right sides of the exhaust not detected. They can all be removed from the PCM with programming.
Old Apr 11, 2008 | 04:00 PM
  #17
camarostripe96's Avatar
From: Academy,tx (Home to Temple/Academy Drag Strip)
but throwing those codes , will it make it knock ? miss fire? or anything like that? what do u suggest i should do, keep the egr/air hookups and buy lt's with egr/air hookups on them?
Old Apr 11, 2008 | 04:30 PM
  #18
ss.slp.ls1's Avatar
If its all properly blocked/capped off there should be no effects beside the SES light being on, which can be tunned out as mentioned above.
Old Apr 11, 2008 | 04:39 PM
  #19
ok so i guess i will delete the egr/air hookups....but to get the tune all i will be doing is paying $150 to get it tuned and all it will do is delete codes and not get any gains?
Old Apr 11, 2008 | 04:43 PM
  #20
ss.slp.ls1's Avatar
I don't know what your current mods are, you should include them in your sig. No, you will not notice any gains from the air/egr delete alone. You may or may not notice something form better A/F ratios, fuel trims, etc. If your car is otherwise stock, I wouldn't expect much.
Old Apr 11, 2008 | 07:05 PM
  #21
i have k&n cold air intake, borla cat back, skip shift eliminator, short throw 6 speed and thats about it .....but i know if i get race style headers i am going to throw codes and then to get it tuned its gonna cost about $200, but tuning it will it do anything or am i paying $200 just to delete the codes? cause if i am just paying $200 just to delete the codes then i will just got with longtube headers with the egr/air hookups u know, cause if thats all i will be paying for is a tune to delete the codes then i am getting headers with the hookups !!! u get my drift
Old Apr 11, 2008 | 09:51 PM
  #22
BigBadBlack93Z's Avatar
talk to some of the tuners or look into getting the software and cable to do it yourself. i think i saw one of the tuners offering a package that was cheaper for tire size changes, fans and probably the emissions stuff vs. paying for a full tune since all they have to do is hook up the computer and change 1 or 2 single settings and not an entire table.
Old Apr 11, 2008 | 09:58 PM
  #23
R&D Speed's Avatar
We make everything you need to remove the EGR and AIR systems from your car.
http://www.rdspeed.com/category.sc?categoryId=4
Old Apr 11, 2008 | 11:13 PM
  #24
ss.slp.ls1's Avatar
If you got the headers, you would see something out of a tune with an intake, headers, and exhaust.
Old Apr 12, 2008 | 12:08 AM
  #25
ok so what should i do , delete or not?
Old Apr 12, 2008 | 12:31 AM
  #26
bombebomb's Avatar
whoa, them block off's aint cheap, I think ill be removing mine before I drop engine back in.
Old Apr 12, 2008 | 08:21 AM
  #27
U talkin about the block off plates? I already have them I'm just stuck in a position trying to figure out what I'm going to do, delete egr/air or keep them? Why pay for a tune if all it does is delete codes and make u light go off ya know, might as well save 200 and het headers with the egr/air hookups!! Anyone agree
Old Apr 12, 2008 | 08:24 AM
  #28
2000GTP's Avatar
Blockoff plates can be found for 15-20 bucks. Some people even make their own and fabricate their own gaskets.
Old Apr 12, 2008 | 08:29 AM
  #29
MTBSully's Avatar
So if i bought something like this http://cgi.ebay.com/ebaymotors/EXTRA...QQcmdZViewItem
thats all i would need to delete both AIR and EGR from my 95 z28 with race headers?
Old Apr 12, 2008 | 08:32 AM
  #30
2000GTP's Avatar
Yes.
