AIR and EGR delete?
Old Apr 2, 2008 | 09:41 PM
MTBSully's Avatar
AIR and EGR delete?
Im sure this has been covered before but here goes. Feel free to link to other threads. How hard is it to do? I know that there arent any performance gains involved but im looking for some LT headers and its hard to find ones with emissions. Any writeups out there on how to delete it? Thanks
Old Apr 3, 2008 | 09:57 AM
2000GTP's Avatar
Pacesetter,Jet-Hot, and Kooks all make LT1 long tubes and they offer them with AIR/EGR fittings.
Old Apr 3, 2008 | 10:05 AM
dangalla's Avatar
the block off plates can be had for cheap from ebay
Old Apr 3, 2008 | 10:13 AM
ss.slp.ls1's Avatar
It's not hard to do, most do it just to clean up the engine bay. Get some block off plates and some vacuum caps and go to work.
Old Apr 3, 2008 | 10:17 AM
2000GTP's Avatar
I've seen some sellers on there even selling chrome ones with bowtie emblems, I thought that was pretty amusing seeing that you can't really get a good view of these things.
Old Apr 3, 2008 | 10:46 AM
What you need to do, and what you will get in the way of codes depends on the year of your car. Why not add a "signature" showing the basic info about your car - year, model, engine, tranny and any major mods.
Old Apr 3, 2008 | 12:16 PM
97SS0594's Avatar
your also going to need to delete the EGR out of your computer or it will run like fat poo.
Old Apr 3, 2008 | 01:32 PM
dangalla's Avatar
hmmm.. you sure it would not just set a code, and maybe, maybe get a little bit of knock
Old Apr 3, 2008 | 01:49 PM
slomarao's Avatar
ya, it will prolly just turn your ses light on.
Old Apr 3, 2008 | 01:55 PM
2000GTP's Avatar
What year is the car? If it is OBD-I, as long as the fuse for the AIR circuit is intact, you shouldn't get an SES light. As for the EGR, it is a hit or miss, but still a possibility that you won't get an SES light for its absence. OBD-II, however, you will surely need tuning to take care of the absence of both the AIR and EGR systems.
Old Apr 3, 2008 | 09:01 PM
MTBSully's Avatar
its a 95 z28 M6 with edelbrock shorty headers right now. So it is OBD-I. Any write -ups on how to delete these things?
Old Apr 3, 2008 | 10:03 PM
Kaj's Avatar
Kaj
shbox.com has the info, look there. It's pretty straightforward, kinda a pain since you'll be working at the rear of the intake manifold to get to the egr system...
Old Apr 11, 2008 | 03:03 PM
camarostripe96's Avatar
From: Academy,tx (Home to Temple/Academy Drag Strip)
i have a 96 trans am lt1 , what do yall recommend i do, delete or not to delete?
Old Apr 11, 2008 | 03:34 PM
It has no affect on performance, whether you leave it there or delete it. Maybe a few # less weight, and a bit more space under the hood.... but that's it.
To remove EGR, remove all the parts shown here, and plug up all the resulting holes:
http://shbox.com/1/egr1.jpg
AIR is a bit more complicated, since what parts you have to delete will depend on whether you had the AIR system recall (95-97) done. The holes in the manifold require an M22 thread oil plug (93-95 except CA emissions A4's). 95 CA emisions A4 and 96/97 require a smaller plug, possibly an M18 (but not sure). The hole in the air duct that the AIR pump suction hose connects to will require a 3/4" vacuum cap.
http://shbox.com/1/air_pump_recall.jpg
http://shbox.com/ci/AIR.jpg
Old Apr 11, 2008 | 03:46 PM
no not less weight cause ur adding longtubes lol jk so it wont hurt AT all just throw a code if that
