Adjusting valves weird question
Old Jul 6, 2005 | 12:34 AM
  #16
Munson's Avatar
Re: Adjusting valves weird question
Just for an update and another question.. I think i have fixed the problem.. I had taken my voltage on the tps before and did again today and couldnt get it right after about 45 minutes of adjusting and re-adjusting the tps sensor i could only come up with a best of .4V idle and 5.0 or higher WOT (i was still throwing tps code wot on this setting) so i decided to unscrew my idle stopper screw on my tb and managed to get a best of .55V idle and 4.9V wot. My question is will this affect anything? having my idle screw sticking out to compensate?
Old Jul 6, 2005 | 08:53 AM
  #17
As long as your IAC counts are in the 20-40 range or so, it will be ok.
Old Jul 6, 2005 | 10:31 AM
  #18
Munson's Avatar
dont you need a pcm scanner to get IAC values? If so i dont have any way of testing them.. Ill go ahead and look that up
Old Jul 6, 2005 | 06:57 PM
  #19
Munson's Avatar
anyone?
Old Jul 6, 2005 | 07:00 PM
  #20
Yes, you need a scanner.
oldschool
Feb 9, 2016 09:21 PM
warmeck
Feb 2, 2015 12:44 AM
97z28k&N
Jan 9, 2015 04:58 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
