Adjusting Valves, Question.
Old Jan 19, 2006 | 07:26 AM
HardcoreRM125's Avatar
If your trying to set the valves using a spin-the-pushrod method, is this right?
The instant you feel even the slightest amount of drag, tighten an additional 1/4 turn, or whatever preload setting you decide to go with?
Is it normal to be able to wiggle the rocker arm end ( The Valve Stem side ) very slightly once the valve is adjusted? It should take some effort to get it too budge, but it should not be so tight you can not move it by hand at all right?
Old Jan 19, 2006 | 07:33 AM
Re: Adjusting Valves, Question.
Yes.
Yes, it is normal for the lifter to immediately bleed down.
Old Jan 19, 2006 | 10:36 AM
Stoopalini's Avatar
Is it possible to adjust the valves on an LT1 with the motor running?
I've done this in the past with old school motors. Just fire it up with the valve cover removed, loosen the rocker till it starts clicking, then tighten till the clicking stops and go 1/4 - 1/2 turn more.
Is there something about the LT1 valve train which makes this method a bad idea?
Thomas.
Old Jan 19, 2006 | 11:08 AM
Colin91Z's Avatar
Thomas.
Works just the same as old school sbc's
Old Jan 19, 2006 | 11:27 AM
Dave89IROC's Avatar
valve train is pretty much the same, all the parts are interchangable
Old Jan 19, 2006 | 09:43 PM
Thomas.
Many adjustment methods (including engine running) are listed on my Tech Page. It's the same as any old SBC.
Old Jan 20, 2006 | 11:05 PM
Other than the fact that it is a pain to get the valve covers off and on fast, No. It takes a little while to tie the wires up if you have OTVC wires and wanna do it with the engine running. Also, you gotta take the serp belt off, to get the alternator off so the valve cover can come off ...
Old Jan 20, 2006 | 11:10 PM
TransAm396's Avatar
I did it with my engine running and it was so easy..oil didnt splash anywhere.
Old Jan 20, 2006 | 11:12 PM
194bird's Avatar
i do mine running but i have a lower mount altenater and all the other useless junk taken off ha
Old Jan 20, 2006 | 11:31 PM
TransAm396's Avatar
i did mine with the alternator off..thats how ive always done it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
R@mpage
Apr 20, 2015 10:02 AM
sseeya
Apr 9, 2015 06:38 AM
